Results 1 to 3 of 3
Thread: 300xs Fluctuating fuel burn
11-15-2022, 08:32 AM #1Junior Member
- Sep 2011
- Louisiana
- 21
I bought a boat with a 2015 mercury 300xs that was recently rigged on my new to me LCB cat. It was upgraded with a new simrad and vessel view. The 300xs has just under 200 hours and runs great, but I noticed my fuel flow numbers have been bouncing up and down at a steady rpm. For the first 5-7 hours I was seeing 15 gallons per hour fuel burn in the 4200 rpm range running 65 mph. Now I am seeing the fuel burn jump around from 14-21 and doesn't seem to settle down. I also have a water pressure sensor error where the water pressure goes to 0. I replaced the sensor with a new sensor and it was working, but is now going in and out. I rigged a manual gauge to check the water pressure and I do in fact have good water pressure. The boat runs good and is not showing any issues while running. Could these issues be due to the new vessel view/ simrad setup? Perhaps a firmware update issue?
I called the local mercury shop, but they can't look at it until December so trying to work out the issues myself because the boat is running fine. Rpms, temps and gps are all holding steady with no issues.
Has anyone heard of any issues like this? Ground issue, network issue? I think the simrad is a simrad go.
Thanks in advance
11-17-2022, 09:47 AM #25000 RPM
- Dec 2019
- Spring Lake MI
- 487
- 38
- 145
- 441
It could be a shared 5v reference with the water pressure going crazy as well. Maybe it is shared with the MAP, coolant or air temp sensor this would have a big affect on fuel burn.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
HydroSkreamin liked this post
11-22-2022, 07:53 PM #3
I think hellbents is onto something…it’s probably time to get it to a dealer and get a log of what’s going on.
My guess is that your 5V power supply is fluctuating or getting pulled to/toward ground, and muddling up the signal to TPS and MAP sensors, which your engine is using to calculate load/fuel demand.
If neither trim nor RPM are fluctuating but your fuel flow is, something is rotten in Denmark…A problem is only a problem when viewed as a problem...
Mercury Tech: 300 pm starts to burn a lot of fuel
By Tranq in forum Technical DiscussionReplies: 7Last Post: 08-13-2021, 10:04 AM -
Un even fuel burn???
By texasvector in forum Technical DiscussionReplies: 51Last Post: 08-31-2015, 12:36 PM -
250 xs ratio / fuel burn
By Porketa in forum Technical DiscussionReplies: 7Last Post: 05-23-2013, 06:52 PM -
300X Fuel Burn
By BluFin in forum Technical DiscussionReplies: 2Last Post: 06-07-2005, 08:53 PM -
200 Pro Max fuel burn???
By 87vantage in forum Technical DiscussionReplies: 6Last Post: 11-15-2004, 09:00 AM
