Results 1 to 4 of 4
11-14-2022, 12:51 AM #15000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
Boat wiring after Rex Shifter install?
I am planning to install a Hotfoot, Rex shifter and blinker trim switch. Installing them seems to be pretty straight forward. I now have OEM Mercury controls with the pigtail.
How is the wiring done now?
Do I need to run each wire from the pigtail to its proper connection point?
It there a wiring kit that can be purchased?
Suggestion?? A better way?If you think this is fun, wait til next weekend!
11-14-2022, 08:47 AM #2
https://www.ebay.com/itm/30469872301...Bk9SR-TUoeaOYQ
Or chop it and just find the key switch and remove the box.1973 Viper - sold
1978 Viking - sold
1995 XB02
11-15-2022, 06:48 PM #3
Don't really need to chop. Split the box in half and all the wiring guts will come out of it. That will yield the wiring harness that the above link takes you to. Key switch hard wired to the harness (that you can then put in your dash) and a bunch of bullet connectors that are for the warning horn, temp, tach, trim sender, trim power+up+down. The trim you can hard wire straight to your trim toggle sw. and the colors will match. The grey wire goes to the tach, the black and the black+yellow go to the kill switch etc. Just put all that stuff in your dash and ditch the control box.
DEN thanked for this postDavid - WI liked this post
11-15-2022, 09:22 PM #45000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
After posting this, I did search for marine key switches with a push choke and many are out there. Was looking for a little better quality the plastic.
looks like the way to go, thanks for the advise!If you think this is fun, wait til next weekend!
Smart craft,oil tank,merc wiring harness, shifter
By Matt1450 in forum Misc. Parts and AccessoriesReplies: 9Last Post: 03-05-2019, 03:16 PM -
HOW TO, REX marine shifter install
By dave02 in forum Custom Rigging and Metal FabricationReplies: 1Last Post: 01-26-2014, 08:31 PM
