Results 1 to 9 of 9
    Oct 2012
    canada
    hydrostream hst 1990
    hi folks need some advice i have a hst with 10 inches of set back running a old fresh build gt235 with some mods done heads etc would like some advice on 2 props 1st something for the river quick to top end 2nd something for top end i have a 27 srx and also a 30 et lightning any advice you have would be great the motor is in the 250 hp range thanks steve
    Jun 2018
    Floating around
    What speed/rpm are you getting now?
    Oct 2012
    canada
    i have never ran it with this motor just put in on not wired yet just trying to get some feelers out there thanks steve
    Jun 2018
    Floating around
    By most accounts you have two of the best props out there for your set up. Do you have solid mounts and a low water pickup? Water pressure gauge?
    Oct 2012
    canada
    yes i do have solid mounts l w p and installing water pressure gauge thanks steve
    Jun 2018
    Floating around
    It sure sounds to me that your on a solid trajectory. You have a great hull, plenty of power, a couple great props, and a solid set up. I can admit to buying a ton of props because i like to try them all but i cant think of anything to suggest with yours thats gonna run better than a 30et. Maybe theres some four blade options worth trying but if your not looking to waste money, once you run it and know your speed and rpm you can use a prop slip calculator to decide what you want to try next.
    im guessing your gonna love both of those props
    Oct 2012
    canada
    thanks lakefever for your input i cant waite for summer to come back around getting cold here in ontario thanks again steve berry
  8. Likes LakeFever liked this post
  9. #8
    Belgium
    Hi Steve,
    I have an HST with a 200 merc (stock except reeds and tuner). I have a hydraulic 10" lift. The boat runs very well. I tried a lot of props. For cruising, carrying weight a solas scorpion is very hard to beat. Best speed I had with the srx 29. A lot of props run very well on mine. I like the hydaulic lift to get it up and running and that jack the engine up.
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  10. #9
    Apr 2014
    nj
    this post brings back memories of Bob Maskos HST he ran on mullica river in early 90's , v-8 omc on 8 inch one off hand made on bridgeport as well as formula one lower ran 120 , i was in back seat going 110 .
  11. Likes LakeFever, V pads, rgsauger liked this post
  1. hydrostream hst 1990
    By steve berry in forum Technical Discussion
    Last Post: 11-09-2022, 07:24 AM
  2. hydrostream hst 1990
    By steve berry in forum General Boating Discussion
    Last Post: 11-06-2022, 08:26 AM
  3. 1990 Hydrostream Vegas XT
    By madsnrn in forum Hulls up to 20'
    Last Post: 03-08-2018, 09:03 PM
