Results 1 to 2 of 2
    Jan 2020
    Pinole, Ca
    2016 150 4s efi Mercury high hours
    25" motor with 5000 hours on it. It has been well taken care of including impeller, spark plugs, thermostat and belt being changed every year at a minimum and oil, oil filter, gear oil and fuel filter changed every 100 to 150 hours. 8 months ago I did a major service on it to verify it would get though this year with no issues while I waited for a new motor to be available from mercury. That service included injector cleaning (only the second time in its life if had that) and a compression test to match the flow of the injectors to the cylinders. The compression was from 173 to 180 psi and the injectors were within 2% after cleaning. The motor runs flawlessly now and is on a boat ready for a test drive if any local buyer wants to go out. halfway through this year I blew the lower unit up (cracked the pinion gear) so that was replaced with a brand new mercury lower. The lower unit was the only major issue I have had with this engine; other than that it has just had regular service items changed. Great reliable motor. Even when the lower went it still got me home, it was just ticking. Found out it had a cracked pinion tooth. Prop not included.
    2016 model year 3.0L efi 4stroke 25" (XL)
    $7000 obo
ID:	511994Click image for larger version.
ID:	511995Click image for larger version.
ID:	511996Click image for larger version.
    Call me if you have any questions: Jacob 510-418-4911
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Jan 2020
    Pinole, Ca
    Price drop to 6000 + shipping.
  1. 2016 21 Liberator. Like new 17.6 hours
    By WILDMAN in forum Hulls larger than 20'
    Last Post: 07-03-2018, 04:00 PM
  2. For Sale- 2016 Hustler Talon 25 w/ Merc Racing 565. Only 39 hours!!
    By RDAglock in forum Hulls larger than 20'
    Last Post: 03-20-2018, 11:17 AM
  3. Two 2016 300xs motors. 21 hours, full warrantee
    By WILDMAN in forum Outboard Engines
    Last Post: 06-26-2017, 02:23 PM
