Results 16 to 27 of 27
11-09-2022, 06:38 PM #16Member
- Apr 2022
- melbourne australia
- 33
- 40
Hi yes rebuild and restore of complete boat and motor (I’m a mechanic) I’m very fussy and want everything immaculate as for motor I thought it was late 80s but labels worn off we’ve had boat from new in 1997 20 xlt flightcraft and put late 80s black max but this is a massive project for me but I will have a fully restored ski boat and old 200 merc ,this makes me happy
11-09-2022, 07:06 PM #17Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
11-10-2022, 03:07 AM #18
@hobbymad I can see your pictures. My motor did not originally have the separate rectifier & regulator. I do not know why you have 2 red wires coming from the engine loom. You should be able to figure it out by tracing the wires and understanding which wire goes where, and why:
- From the battery you need a positive lead to the + terminal on the starter solenoid (which is used as a central + terminal on your engine).
- The red wire(s) from the rectifier or the combined rectifier/regulator need to be connected to the battery in order to charge it, which is why they are usually also connected to the + terminal on the starter solenoid
- The red wire that goes into the engine loom (which connects to the control box loom) feeds the ignition switch and the trim button in the control box, it needs a constant +, which is why it is usually connected to the + terminal on the starter solenoid.
Even though the wiring can be routed differently between years, it comes down to the description above.
Two examples below with separate rectifier (note that the regulator is not included here).
One example with two rectifiers/regulators
11-10-2022, 05:24 AM #19Member
- Apr 2022
- 33
- 40
Roye thanks mate and im happy to go chasing wireing to find out whats what but just thought there may have been someone with the same set up as mine thats done the rec conversion to save me the trial and errors that may occur,but no probs il sort it out and you
have been a great help thank you.
11-10-2022, 05:36 AM #20
You're welcome and good luck, let us know how it works out!
11-10-2022, 07:19 AM #21
you should have a small red from tha harness or from batt term on tha soleniod already that went to tha rectifier.. it can make a joint with it or it can go straight to tha solenoid batt. term (red)... some fuse it @ 20 amps.... some don't......
its actually tha ign. (key) switch hot...Last edited by tlwjkw; 11-10-2022 at 07:38 AM.
11-10-2022, 10:20 PM #22
hobbymad liked this post
11-11-2022, 06:53 AM #23
you have really started something now.. looked at a coupla motors both 16 and 40's plus every wirin' dia.. can get my hands on and cannot find a "pink" in any of tha ign/chargin' circuits
if its red, no mater tha size, it either starts or stops atta 12v positive batt. terminal......may or may not be fused.
11-11-2022, 01:02 PM #24
Im with him ^^^^
11-11-2022, 11:55 PM #25
Well, it started as a 40 amp water cooled 1990 setup. I’ll take another look but last night, it was pink! Lol
11-12-2022, 06:52 AM #26
only one pink..... it should not be anywhere on tha power head..
11-12-2022, 10:56 PM #27
I hear what you’re saying but I’m looking at what I’m seeing…I’ll look harder again tomorrow
1985 Mercury V200
By Vector Thunder Bay in forum Outboard EnginesReplies: 2Last Post: 04-21-2019, 10:54 AM -
OMC Tech: rectifier wiring
By bulldogdaddy in forum Technical DiscussionReplies: 1Last Post: 08-01-2012, 09:23 PM -
1988 2.4 175 rectifier help
By Reaction19 in forum Technical DiscussionReplies: 16Last Post: 08-09-2011, 11:23 AM -
Mercury Tech: 2,4 of year 1988, V175 to V200
By tuoppix in forum Technical DiscussionReplies: 0Last Post: 09-09-2009, 02:40 AM -
Merc Regulator and Rectifier Wiring Schematic
By Matt in forum Technical DiscussionReplies: 1Last Post: 08-17-2001, 07:01 AM
