Results 1 to 10 of 10
Thread: Failing clear gel
10-27-2022, 06:34 AM #1
Failing clear gel
Recent purchase of a 1976 Glastron CVX Jet hull has guess what, failing gel coat.
This one interestingly has no failure into the flake/colored gel. Just affecting the clear.
There are regions of good clear, regions with non existent clear and areas where I can scratch the failed clear off with my fingernail.
My other blue hull has failed gel to the point that major portions of flake are well above the resin, it is consistently bad.
In this case I am not sure what type of abrasive process to remove failed clear, or all clear to the point where I can spray new clear coat?
Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
10-27-2022, 08:18 AM #26000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
Walnut mix
10-27-2022, 09:04 AM #3
I have some plastic bead here, I will order in some walnut shell, thank you.
Regards,
Charlie North
10-27-2022, 11:19 PM #4
I used a flat razor blade to get a bunch of my dried up clear coat off. Used soapy water, too. Super glued a couple of razor blades to the end of wooden paint stir sticks. Perfect.
10-28-2022, 05:19 AM #5Regards,
Charlie North
10-29-2022, 12:07 AM #61990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
CharlieN liked this post
10-30-2022, 07:09 AM #75000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Your on the right track just using a razor blade - then go to an orbital sander and finish off the removal process . I doubt this is gel but rather cheap automotive clear that is de;laminating from the gelcoat .
Be aware that when you sand the actual gel - you will run into the metal flake and it will sand the flake edges "silver ' - but its easier to do this vs actually spraying out metal flake and then clearing .
The correct way is to simply spray metal flake - bury the flake in clear then sand,buff, wax.Now it will pop like new for just a small bit more work or effort .
CUDA liked this post
10-31-2022, 04:43 AM #8
This is the original factory gel from 1976 I will not sand over the flake. I know better than that.
Regards,
Charlie North
11-03-2022, 04:14 PM #9
I also used a razor blade on the top cap of my Bullet bass boat. Took about 10 hours to remove the clear coat paint.
Had a buddy offer to clear coat it afterwards. I said, no thanks.
11-08-2022, 11:26 PM #10
Quality , quality, quality of product makes a BIG difference.
https://www.awlgrip.com/products/fil...grip-hdt-clearWe have invented the world; WE see
Mercury Offshore engine mounts failing - video
By mariawhitetrash in forum General Boating DiscussionReplies: 14Last Post: 06-06-2012, 07:06 PM -
Anyone ever heard of Hyd. steering failing??
By WATERWINGS in forum Technical DiscussionReplies: 10Last Post: 10-29-2007, 09:17 AM -
clear coat OR not to clear coat that is the question.
By nitewolf in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 09-03-2002, 03:03 PM
