Results 1 to 7 of 7
    Jul 2021
    fort lauderdale
    Looking for someone to shoot metal flake gelcoat.
    I'm at the point in the restoration of my 1975 18SS Sidewinder that I'm looking for someone to shoot the hull with metal flake gel in south Florida up to central FL. Boat is currently in OK. Any suggestions or help appreciated...not sure if this is posted in the right place. Thanks
    35 Post(s)
    Metal Flake Technique
    Quote Originally Posted by jimmie jam View Post
    Shooting metal flake gelcoat is becoming a lost art in boat building. Recoating a hull that's already built has its own set of problems. Metal flake layups start in a mold with a gelcoat in clear, then a mix containing the glitter and then usually backed up with black for background. The trick is in the second coat with getting the glitter mix uniform so that a minimum of the flakes are not standing on their edges. All of this process cannot end up with a gelcoat that is too thick and won't bond with the glass substrate. Stacking glitter on top of a hull surface that already exists is easier said than done. Not sure it is worth the effort and $$$. You might want to consider a paint overlayer in Imron in a metallic that closely matches your metalflake? Sometimes an Imron clearcoat will bring back the luster in your old metalflake provided that UV damage hasn't dulled the glitter.
  3. Thanks jimmie jam thanked for this post
    Jun 2018
    Floating around
    Im shooting metal flake paint on the deck of mine. Using paint for three reasons; 1. I dont care for gel as a topcoat. Its bug time labor intensive and requires frequent polishing 2. With paint i’ll be using a mid coat clear and flop control which helps the flakes lay down flat 3. The shine is glossier and never needs a polish
    Below the water line im using endura which is similar to awlgrip
  5. Thanks jimmie jam thanked for this post
    Likes rgsauger liked this post
    35 Post(s)
    Gelcoat vs Paint Weight Penalty
    Oh, and another thing, gelcoat (resin) is much heavier than paint............
  7. Thanks jimmie jam thanked for this post
    Likes LakeFever liked this post
    Jul 2021
    fort lauderdale
    I have been over the options and will be doing gel and not paint so I'm going to keep searching...all points well taken. This boat was ordered by me new so that's why I'm taking it back to OEM w/gel.
    Jun 2018
    Floating around
    Jack Barsh is in your neck of the woods. If he wont do it? He will know someone local who can.
  10. Thanks jimmie jam thanked for this post
  11. #7
    Jul 2010
    Portland Ore
    I’m wrapping mine for now. I figure it will at least keep what is there out of the elements and it is something I can do myself. Only issue I have run into is the really heavy flake looking vinyl is out of stock for a year thanks to the pandemic. I found a nice metallic silver and red in 60’ rolls. Set me back around $700.
  12. Likes rgsauger liked this post
  1. Metal flake
    By tnelsmn in forum Fiberglass and Composites Discussion
    Last Post: 04-29-2020, 09:19 PM
  2. Clear over Metal flake Gelcoat
    By Mhall222 in forum Fiberglass and Composites Discussion
    Last Post: 03-30-2017, 08:12 PM
  3. Hustler hydrostream putting new Clear Gelcoat over metal flake
    By MERCURY#1 in forum Fiberglass and Composites Discussion
    Last Post: 04-10-2015, 03:38 PM
  4. Replies: 3
    Last Post: 06-01-2005, 08:11 AM
  5. Metal flake gelcoat
    By bw1969 in forum Technical Discussion
    Last Post: 02-06-2002, 09:48 PM
