Results 1 to 6 of 6
10-06-2022, 09:41 PM #15000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Checkmate Pulsare 2100 BR, Hydro Tec 3.3L Yamaha, 16” Sportmaster
2001 Checkmate Pulsare 2100 BR openbow. 10” Stainless marine bracket and 5-½" CMC power jackplate, homemade skid planer. Lowrance color touch screen Elite 9ti graph/plotter/GPS with WiFi and NEMA 2000 network for engine ECM data display. Motorguide wireless trolling motor with foot and key fob controls. Trolling motor has a quick disconnect with mount cover plate when it’s removed. On-board dual-bank battery charger. Bimini top (I’ve never used it), front bow cover, and full all-weather cover. Fresh starting battery. Removable ski tow tripod.
2006 Yamaha 3.3L HPDI originally a 200 hp. It was built up by Hydro Tec in 2010 using a 300hp block with their Phase III mods and parts: HT hot heads, mild porting, blueprinted, velocity stacks, modified reed blocks, carbon fiber reeds, HT exhaust tuner, solid engine mounts, big bore throttle body, intake spacer plate, lightened flywheel. Stock 300Hp ECM tune with 6150 limiter. Problematic factory low pressure lift pumps and water filter have been removed and replaced with a Mallory electric fuel pump and Racor 10-micron water separating filter. The engine was refreshed in 2016 with WSM pistons due to a piston locator pin failure. A rare occurrence with the 3.3 HPDIs but it is a known problem. The WSM pistons solve this. All internal engine work done by Hydro Tec. According to HT, the engine will run on mid-grade gas but I’ve always used premium. I purchased the engine in 2011 with 6 hours on the Phase III build and 120 hours on the ECM. There are 42 hours on the 2016 refresh. The ECM currently shows 196 hours. Compression is 105-108 which equates to about 126-130 at sea level. It has the original 200 hp clamp/bracket with model and serial #s which makes insurability much easier compared to a 300 Hp engine.
16” Short shaft mid, Merc 3.0L Sportmaster 1.62 straight skeg gearcase adapted to the engine using HT parts and machining. Torque tab and Bman foil added. Lakeland Marine billet shift shaft seal with vent kit. There are 82 hours on a 2010 rebuild with a new prop shaft, which was completed before my purchase. Has a new water pump and fresh gear lube.
2001 Checkmate trailer by Trailmaster/Vanguard. Recent new brake actuator installed. Disk brakes, bearings, and wheel seals have been well maintained. New tires and wheels. Spare tire is unused but older. Trailer is ready for cross country travel.
I’ve never run the boat light or at lower elevations. It has run 80 mph on the rev limiter with a 24” Promax prop. This is at 5000’+ elevation mountain lakes with a heavy load: 3 people, several heavy Musky rods, 2 giant tackle boxes, cooler, tool box, extra prop, trolling motor w/deep cycle group 31 battery (90 lbs), 2 anchors and more.... It's being sold with a custom Mark Croxton balanced and blueprinted 24” Bravo I prop for all around performance. With the Bravo, it easily pulls up slalom skiers, can say on plane below 20 mph, and still provides mid 70’s speeds at high altitude while loaded. I would expect significantly higher speeds with a light load, at lower elevations, and a much larger prop.
Yamaha factory engine service manual, YDS interface cable with v1.32 software, extra set of stock heads, folder of documentation, and Sportmaster water hose attachment included.
The boat has been very well maintained, is in great condition, and looks great but does shows a little wear here and there. I am the second owner and have not really used it a lot. It's never been beached on-shore. Obviously fresh water use only. The hull is glossy with no weathered areas. It has the original interior which looks great. There are no rips, cracking, or split seams in the vinyl but there are some small scuffs and light stains. The carpet is good with some matting but no worn areas. The front seat backs (facing forward) each have a dark stain where the Checkmate fabric logo was glued on. The seat back fabric can be sent to “Gotcha Covered of Checkmate” to have the logo embroidered over the stain. The motor hood has some scratches on the top. The engine setback bracket has some powder coat finish coming off. The trailer has the usual rock chips on the fenders and few other areas.
This is a very difficult decision to sell but our boating days appear to be over. I’ve only used it 4 times in the last 2 years. I never thought I would sell it. It's been my dream family performance fish and ski rig for 12 years. I’m located in northern Utah. The boat, motor, and trailer each have Utah titles that are in my name and in-hand.
$22,500
PM, text or call Jeff 8 0 one - 7 2 five - 7 7 four fourLast edited by lance; 10-07-2022 at 08:02 AM.
10-07-2022, 09:35 PM #25000 RPM
- Jan 2021
- Lake Muskoka,Ontario
- 170
- 10
- 57
Would you sell without motor? If so-how much?
10-08-2022, 08:21 AM #35000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I'm not going to separate at this time.
11-22-2022, 10:04 AM #45000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Still for sale
11-22-2022, 10:41 PM #55000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Sale pending.
11-23-2022, 04:25 PM #65000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Thanks for all the interest. It has been sold.
Checkmate pulsare 2100
By Esox4130 in forum Hulls up to 20'Replies: 18Last Post: 01-17-2017, 07:06 PM -
By SippyRat in forum Hulls larger than 20'Replies: 7Last Post: 11-19-2016, 12:47 PM -
checkmate 2100 pulsare
By bullwhipjkg in forum General Boating DiscussionReplies: 3Last Post: 03-09-2013, 10:56 AM -
Checkmate Pulsare 2000 BR VS Pulsare 2100
By promax150 in forum General Boating DiscussionReplies: 1Last Post: 07-19-2007, 09:09 AM
