Results 1 to 8 of 8
    Aug 2022
    Pennsylvania
    Will this trim pump work 1980 merc
    Will this trim and tilt pump setup work for a 1980 merc 200hp single ram trim and tilt.
    Attached Thumbnails Attached Thumbnails Screenshot_20221002-172423_Facebook.jpg
    ...yes. the trick is in finding the "brass" adapters that thread into the pumps valve body you have there. the reason brass adapters are always utilized, is yes, to adapt different trim line ends...but more importantly, to never bugger up the threads in the easy-to-bugger-up aluminum female threads of the valve body by taking them off & on & off & on. and also the possibility of also stripping the same female threads by over tightening a stainless trim-hose end into the same valve body. in a salt envirement the brass adapters also cut down on corrosion issues. don't ask me where to find a couple of brass adapters. i've been out of circulation too long now, lol. someone else here should chime in that knows...
    Jul 2014
    SOUTH CAROLINA
    Quote Originally Posted by fujimo View Post
    ...yes. The trick is in finding the "brass" adapters that thread into the pumps valve body you have there. The reason brass adapters are always utilized, is yes, to adapt different trim line ends...but more importantly, to never bugger up the threads in the easy-to-bugger-up aluminum female threads of the valve body by taking them off & on & off & on. And also the possibility of also stripping the same female threads by over tightening a stainless trim-hose end into the same valve body. In a salt envirement the brass adapters also cut down on corrosion issues. Don't ask me where to find a couple of brass adapters. I've been out of circulation too long now, lol. Someone else here should chime in that knows...
    summit racing
    Aug 2022
    Pennsylvania
    What are the sizes for summit racing
    35 Post(s)
    Take your trim pump and lines in to a local hydraulics shop and supply business. They are around this kind of stuff all the time. Counter guy should have you fixed up in 5 minutes.
  6. Likes 1954bmw liked this post
    ...what zebra said. if memory serves, it required two brass fittings per line, at the valve body, because of the unusual trim line fitting sizing. maybe they make the proper singular adapter brass fitting these days. been a long time...
    Mar 2004
    Are there not two types of pump also? A low pressure high volume and a high presssure low volume?
  9. #8
    Jul 2014
    SOUTH CAROLINA
    Quote Originally Posted by daygotires View Post
    what are the sizes for summit racing
    summit racing p/n # aerfbm2930 4an to 7/16-24 inverted flare. Not brass. Not necessary. Will connect m/c trim pump to outboard. I just did one.
  1. 1980 merc 200 trim and tilt question
    By Daygotires in forum Technical Discussion
    Last Post: 09-22-2022, 08:26 PM
  2. trim pump doesnt work... i officially have no luck.
    By hst714 in forum Technical Discussion
    Last Post: 07-27-2010, 11:01 PM
  3. Mercury Racing Trim Pump work with Offshore style clamp?
    By JUPITER PULSARE in forum Technical Discussion
    Last Post: 07-10-2010, 03:13 PM
