Results 1 to 3 of 3
Thread: stator test v200
10-01-2022, 07:06 AM #1Member
- Apr 2022
- melbourne australia
- 33
- 40
stator test v200
hi guys i have a v200 black max and im testing the stator just the resistance tests and between the b/w and r/w i have 4230 ohhms and between the red and blue i have 4200 ohhms but the manual i have says should be 5400to6200?? and testing red to ground i have 72ohhms and r/w to ground i have 72 ohhms manual says 125-175? has anyone done this test on blackmax 200? are my figures ok? is the manual wrong? please help also my stator part no is 398-5454-a34. thank you
10-01-2022, 11:41 AM #2
In my experience the ohm tests are almost a waste of time. Get a DVA meter to check output. What is the engine doing to make you check stator?
RockTeam Junk
pcrussell50 thanked for this postpcrussell50, OnPad liked this post
10-01-2022, 06:22 PM #3
I agree with rock. Ohms are subject to temp and other factors. Variations are OK. The only real value in an ohm test is checking for shorts and opens.
Jim
Mercury Tech: 1987 V200 Blackmax stator replacement.
By graham180869 in forum Technical DiscussionReplies: 1Last Post: 08-25-2012, 09:52 AM -
how do I test my stator?
By crawdad369 in forum Technical DiscussionReplies: 2Last Post: 06-04-2009, 04:55 PM -
stator test
By wrenchhead30 in forum Technical DiscussionReplies: 1Last Post: 06-30-2006, 09:23 PM -
how to test stator
By SAMMY CORLEY in forum Technical DiscussionReplies: 1Last Post: 10-17-2004, 08:35 PM -
How to test a stator
By Jerry Millington in forum Technical DiscussionReplies: 1Last Post: 07-12-2001, 09:33 PM
