Results 1 to 10 of 10
    Mar 2004
    Brooklyn Park, MN
    USED 2.5 lower rod bearings - PLASTIC CAGE BEARING - USED
    I have a set out of my PM I just rebuilt. I advise not using these but apparently some use them still and want them so here they are. 75.00 shipped for all or make me an offer!!!!
Name:	PM plastic bearing.PNG
ID:	510433Click image for larger version.
Name:	PM plastic bearings 2.jpg
    1973 Viper
    1978 Viking
    Jul 2002
    FT WORTH, TEXAS
    Ive used a ton of these in consumer motas but the bearings are replaceable which i did on all of them ,moma merc thinks they are ok but i also used metal cage bearing on my go faster stuff even though quite a few Promaxs i tore down came with these in them
    Jan 2020
    Pinole, Ca
    I did a service rebuild on a 260 recently and it had these in it. Motor had 100 hr or so on it since it was rebuilt and the bearings seemed fine. I don't know how they last, but they do.
    Jun 2018
    Floating around
    Im guessing sloppy bores and these bearings = trouble. Too much rod movement would probably take them out
    Pekin, IL
    I have seen far more plastic caged than metal caged. I used metal on screamers but plastic on nearly everything else with very good results. To each their own I guess.
    Rock
    Team Junk
  6. Likes LakeFever, TEXAS20225 liked this post
    Mar 2004
    Brooklyn Park, MN
    Who needs them! haha. Make an offer!
    1973 Viper
    1978 Viking
    Jun 2018
    Floating around
    Quote Originally Posted by rock View Post
    Rock
    Theres always the must do mods for boats/cars/trucks when 99% of the time they are probably not required. There is also the blame the parts for shoddy workmanship types who get a lot of these mod rumors started lol. As for me? I have not enough experience Im a newb to the V6 merc so I'm following along the suggested mods
  9. #8
    Aug 2019
    Palmharbor
    Well the
    Reciprocating wt is less?? But I have found Aluminum bolts holding X3 BMW motor mounts to the block which break and cost you a 500 dollar water pump and the bolts cost 14& each !! Or go to ACE 50 each grade 5 point is it’s a Profit margin for mercury but we’re playing the risk game
  10. #9
    Aug 2020
    Dickson, Tennessee
    The only bearing ive ever eaten which broke the crank in the process was steel caged. And every donor motor ive torn down with decades of water time had plastic cage bearings and not a single one was damaged. Some motors had oil pump failure and extreme overheat. Some melted and stuck a slug. Bearings were all normal. And i still put steel cages in every one i assemble. Hmmm. Makes you wonder when you think about it lol.
  11. Likes OnPad liked this post
    Mar 2004
    Brooklyn Park, MN
    ttt
    1973 Viper
    1978 Viking
  1. Plastic cage rod bearings vs metal cage mercury 2.5
    By Davidpkl in forum Technical Discussion
    Last Post: 07-16-2015, 09:20 AM
  2. 2.5 want to use metal cage bearings,whats the part numbers
    By camaro7081 in forum Technical Discussion
    Last Post: 01-11-2007, 07:43 AM
  3. top end cap bearing plastic cage,can it be change to metal cage
    Last Post: 12-24-2006, 05:02 PM
