Results 1 to 15 of 16
Thread: V6 Powerhead Studs Question
09-20-2022, 08:35 PM #1Junior Member
- Feb 2021
- Canada
- 17
Rebuilding another Merc V6 powerhead, this one being a Laser 220 EFI. This powerhead came with a couple broken/missing studs that go into the bottom, which goes through top of midsection to tighten down powerhead. Not a big deal, I got lots from donor motors, but I was wondering a few things about installation.
I know of several ways to remove/install these, but was wondering which method some of you use? Also, I can't find any notation anywhere in my service manuals with regards to this procedure, could not find online. They are listed in the parts breakdown, but no number beside them in the torque field either.
Most studs like these (threaded on both ends) usually are not meant to be torqued down very much or at all, so was wondering is that the case with these also, do you use threadlocker and/or torque them down to a certain value?
Thanks ahead of time for any info
09-20-2022, 10:32 PM #2
I use a stud installer/remover that goes on a 1/2" drive ratchet. This works most of the time unless the stud is really stuck; in that case I run two nuts against each other to make a jamb and then run the top nut outwards and it pulls the stud. I install ph studs with red loctite and the same stud tool. It puts them in plenty tight untill it starts slipping. Really you just need to send the stud in till its seated. If you tighten with any significant amount of torque it will bottom out the threads on the shoulder of the stud and start splitting the casting of the block. The threads in the block are deeper than the stud threads.
09-20-2022, 11:01 PM #3
Dittos on the double nut technique
09-21-2022, 12:18 AM #4Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
I don’t have a stud extractor so that’s what I would have done anyway
As for the red thread locker: correct me if I’m wrong here but if you tighten the nuts during install to the right torque won’t the pre-load effectively prevent the studs from unscrewing even without the thread locker?
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
09-21-2022, 12:29 AM #5
pcrussell50 thanked for this post
09-21-2022, 01:00 AM #6Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
09-21-2022, 02:46 AM #7Junior Member
- Feb 2021
- Canada
- 17
Thanks for the responses folks, I was also using the double nut method (on ph studs and also the lower unit studs) but just found the same extractor/installer that 25two.stroke mentioned for $20 (I believe -- knurl type) so I think I'll get one just for simplicity and prevent thread damage. Good to know I was doing it right in general (not torquing down, just snug), just didn't use threadlocker but I may start doing that as I have seen them come loose when removing the nuts before on other units (which ended up being a PITA to remove due to rust and couldn't get good grip on the bolt), but have never seen them get loose on their own.
David - WI liked this post
09-21-2022, 07:50 AM #8
Finger tight .. with grease. Grease the length of the stud .. unless you enjoy using the "Alabama blue wrench" in future disassembly ...
09-21-2022, 12:14 PM #9
The factory does use thread locker on the studs. Even through the optimax age they use loctite. Yeah the loctite isn't to prevent backing out while running, I have never seen that myself unless the midsection cracked. Its mostly there to keep the stud in the block when you back the nuts off later.
pcrussell50, 86brown thanked for this post
09-23-2022, 11:57 AM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19200
- 3 Post(s)
09-23-2022, 04:25 PM #11Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
Adding another. IIRC from Carroll Smith’s epic book on nuts bolts fasteners and (air/auto/marine) plumbing, it jives with what Chaz has told us.
I guess if you didn’t use thread locker and the stud starts coming out with the nut, it would eventually bottom against the exhaust plate. Then you would have to hook up the hoist and pull up. Which is what I do anyway when I’m working on powerhead fasteners.
__________
the wet:
the dry:
2003 bmw ///M5
09-23-2022, 05:17 PM #126000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
09-23-2022, 05:20 PM #13Junior Member
- Feb 2021
- Canada
- 17
2 or 3 Ugga Dugga's by hand should do
pcrussell50 liked this post
09-23-2022, 10:50 PM #14
Fugimoto, are ya mad at me brudda .. ??? Ohh, wait, I wuz havin a flashback ..
My mom was the only one to call me Charles .. but only when she was pizzed at me .. which in my teenage years .. I gave her plenty reason to be .. I rekkon in today's language it would be written :... CHARLES
Don't feel for her .. she would take my kid to toys-R-us .. buy him the loudest most obnoxious toys she could find. Buy him a large Mountain Dew and one of everything on the candy rack .. then drop him off , Son I'm going home to take a nap, Yea mom, I'd love to take a nap too .. but look at what ya did to your grandson. She said .. grand-ma's revenge .. And I waited a long time to get it ..
Yes ma'am, love ya, drive safe .. Sure miss that ole gal ..
OK , my eye's are dry now ..
Powerhead studs :
The factory could put em in with concrete .. whadda they care, they never have to take em out ever again.
How easy was it to get the powerhead and adapter plate separated ..? Some salty dogs I've have to ruin the adapter to save the block. More times than not .. it takes a little heat to get them to move.
Then them frog blocks .. 250xs, 300x, 300xs, sorry sir .. I gave your Alodine a different shade around the bottom ..
&%$^*% factory put the studs in with concrete and an impact driver ..
About 45 years ago, I bought a collet type stud extractor. I really need a new one, I've fixed the keyway ... too many times .. I have 7/16" + 1/2" collets for doin BB Chevys, and 8 and 10 mm for originally doing motorcycles, but now outboard stuff. Everything else is double nutted. I had one of those knurled eccentric things, but threw it in the garbage when it slipped and scarred a couple of studs. I won't deliver parts that look like that.
Why did the O.P. or anyone else for that matter take the studs out of the block .. ??
Fits in the wash tank, blast cabinet, weld bench, boring bar, oven, honing tank, and just easier to assemble without them in the way.
When I do a block (all parts really) I do all gasket surfaces, chase every thread (or repair the hole) that concrete really leaves a mess behind ... barf.
Why grease .. ? See part about concrete .. red lock-tite .. is for stuff you don't want to ever come out. And don't mind ruining the nut and bolt side of a fastener. Only thing worse is green.
I use blue in a few situations .. but I always keep in mind that it has no lubrication properties. Every bolt mfg and every machinist handbook states in one form or another .. torque with light machine oil.
So you lightly grease up aprox an inch of thread on a powerhead stud and run it in by hand.. maybe double nut if both the hole and stud haven't been prepped properly.
So you have either seated the stud lightly on the shoulder , or are getting ready to.
You hang the parts together .. everybody's seated evenly on the gasket and dowels.
In the case of a 3.0L , you start your 10 mm nut which is 10 mm tall + the nylon. Is the stud going to stay put .. or seat the shoulder under the resistance of the nylock and then bedded in from the same torque of the nut ??
Three years later when the guy comes back for another freshen up, the nylon will have gone thru a million heat cycles .. and like myself, will nowhere near as strong as I / it use to be.
So you start taking the nuts off .. who's gonna win ???
An old nylock with 10 mm's of threads ..
Or .. a stud with an inch+ worth of threads that is "high centered" on the shoulder @ 45 ft/lbs then ran thru 3 1/2" of water logged grease and then another inch of aluminum (top ring of the can)
In the strange event that (guys that can break an anvil with a rubber mallet) you loosen the stud instead of the nut ... seems to me you were taking the nuts off to remove the powerhead ..
Then just keep on removing nut, turning studs out of the powerhead, until all ten of them are loose / off .. lift powerhead out of the way. Push the stud/nut up, double nut the stud above the adapter plate. Remove the nut from the bottom.
As your disassembling the powerhead, it might even dawn on you that you are ahead of the game .. when it comes time to take the studs out of the block .. and you won't need the Alabama blue wrench to remove the remaining studs ...
Chaz = wunderin, why is common sense, so uncommon these days ...
09-23-2022, 11:18 PM #15Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
I'm de-salting a salty old dog, to live out it's sunset years in fresh water. I managed to save the adapter and not even use heat... but it was a fight. The previous wrench had greased the studs, thank goodness.
If I decide to pull the studs, I'll chase the holes and put them back finger tight with some light grease. This is what I did with head and main studs on my SBF road race engines. But the engine itself is healthy, with 120/6 and 2-4% leak so I don't plan on pulling it apart except for CCMS reeds.
__________
the wet:
the dry:
2003 bmw ///M5
WTB Powerhead studs
By PaulR in forum Parts WantedReplies: 5Last Post: 08-25-2016, 10:25 PM -
2.4 powerhead studs & base gasket question, ASAP.
By LikwidCourage in forum Technical DiscussionReplies: 7Last Post: 04-11-2006, 08:56 AM -
powerhead studs...
By LakeRacer99 in forum Technical DiscussionReplies: 1Last Post: 06-24-2003, 04:03 PM
