Results 1 to 10 of 10
    Jul 2007
    Hamilton Ohio
    2.5L Crankshafts
    Found one, thx
    What's everybody doing for crankshaft journal repairs ? Good cranks are getting hard to find these days for a reasonable price so are there options for journal repairs that some of you may have used that you'd care to share as I've got one that needs a journal repair.
    Thanks
    Gary
    Growing old is inevitable, growing up is optional.......
    Sep 2006
    Key Largo, Fl
    Find a good used crank,it will be better than a repaired one,and be less expensive than shipping and repair...I will not use a repaired crank.
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by ChrisCarsonMarine View Post
    Hey Chris,
    Long time no talk, hope your doing great. I've been searching for a good used crank but pick'ns are slim at least for a reasonable priced one . I'm with you on repaired cranks, it would be a last resort.
    Thanks,
    Gary
    Gary
    Nov 2021
    N. Idaho
    Shoelace and emory cloth, for my personal consuption, with nothing to lose.
    If you got something to lose, or your damage is more than .001, listen to Chris.
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by OnPad View Post
    Damage is well beyond a .001 flaw. Found a crank in excellent shape yesterday so I'm good to go.
    Gary
    Jun 2018
    Floating around
    Im sure theres a market for some over sized bearings so cranks can be ground down
    Sep 2006
    Key Largo, Fl
    Been there,Done that...long ago when the inline sixes were the standard work motor down here i made my living rebuilding them,and I did find a rod needle around .0015 larger in diameter(don't remember exactly)that would allow a couple thou polish off the crank,and 001 out of the rod...Worked fine,had to keep notes.
    Problem is the crank journels are a little like M&M's,hard shell over soft inside.The rockwell 61-62 is only 5-7 thousandths thick,so there is precious little to polish before getting too thin to hold up.Grinding like automotive cranks is not an option,Chris
  8. Thanks LakeFever, rgsauger thanked for this post
    Likes LakeFever liked this post
  9. #8
    Jun 2018
    Floating around
    I had no idea these were case hardened. Well there goes that option
  10. #9
    Aug 2020
    Dickson, Tennessee
    When i was on a crank hunt i did find a company out in cali that would only work one journal on a merc crank. They said any more than one is too sketchy. But from what i understood, they spray weld to build up and then grind down to size so the shell is still hard. May be an option in the future if you run into one that only needs one journal repaired.
  11. Thanks LakeFever thanked for this post
    Jul 2007
    Hamilton Ohio
    Found a good used one, thx
    Gary
  13. Likes Smalltownbassin liked this post
  1. Mercury Tech: 2.4 crankshafts
    By firemant15x in forum Technical Discussion
    Last Post: 07-26-2009, 03:24 AM
  2. V6 Crankshafts
    By ragvette1973 in forum Technical Discussion
    Last Post: 01-09-2008, 10:06 AM
