Results 16 to 30 of 34
09-14-2022, 05:21 PM #16Member
- Aug 2022
- Australia
- 45
thanks Chris. A lot of information to take in. Considering my engine doesn’t have a regulator, only rectifier and spikes to 17v will this be ok with depth sounder and chart plotter.
I don’t have a small start battery, I have separate house and start batteries connected by auto charge relay. Short cable runs.
pete
09-14-2022, 05:22 PM #17Member
- Aug 2022
- Australia
- 45
09-15-2022, 12:29 AM #18
I run the combination rectifier/regulator on my 16 amp 200 merc. I am never over about 14.5 or 14.6. 17 volts is too high for modern electronics. You can find these units on Amazon or eBay for 25 or $30. There are more expensive ones out there but they all seem to function about the same in my experience. Buy two. One for a spare.
09-15-2022, 12:44 AM #19Member
- Aug 2022
- Australia
- 45
09-15-2022, 04:12 AM #20Member
- Aug 2022
- Australia
- 45
09-16-2022, 12:32 AM #21
So the fact that you only have a rectifier probably means that you are a nine amp or a 16 amp system. I do not believe that they had 40 amp charging systems in 1983. I might be mistaken though. You can pull the serial number and probably get an idea. Is your fly wheel dark green or is it red?
09-16-2022, 12:34 AM #22
Something like this
https://www.google.com/search?q=merc...obile&ie=UTF-81990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
09-16-2022, 12:35 AM #231990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
09-16-2022, 04:24 AM #24Member
- Aug 2022
- Australia
- 45
09-17-2022, 12:05 AM #25
The six wire regulator has two yellows, two reds, one black for the ground, and one gray for your tachometer. That’s the way I would go i believe. If it does not have a black, then it will ground through the housing.
09-17-2022, 03:41 AM #26Member
- Aug 2022
- Australia
- 45
Where would the second red wire go?
09-17-2022, 07:45 AM #27
Check me but just going purely from memory, one of them goes to a common lug on the starter solenoid and I think the other one goes into the wiring harness. Double check me on this though. Should not be that hard to find a schematic.
09-17-2022, 03:19 PM #28Member
- Aug 2022
- Australia
- 45
Thanks again rgsauger.
I’m emailing CDI to see if they can shed light on my situation
pete
09-17-2022, 06:50 PM #29Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
That is a good plan. Let us know what you find out. They sell the regulator/rectifier combination that I think is the one you want.
I only have schematics/manuals for 1983 (rectifier only) and 1990 (water cooled regulator).
BUT
My 1987 2.0 has a separate regulator from the rectifier. I'll take a look when I get back there to see how it is wired. Might be a while.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
09-18-2022, 01:28 AM #30
It will wire up the same as the water cooled regulator if you can post a schematic from that. The water cooled had two yellows and two reds. And the gray.
CDI or OEM regulator/rectifier??
By seef158 in forum Technical DiscussionReplies: 3Last Post: 06-25-2015, 09:38 PM
