Results 1 to 8 of 8
Thread: Aftermarket injectors
08-25-2022, 12:00 PM #15000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Has anyone had experience with aftermarket injectors? The price seems too good to be true. Is it worth the risk?
1986 Baker 18 Mod VP, Yamaha 175
2001 Crest Pontoon, 150 Opti
1968 Sears 14' aluminum, Merc 110
08-25-2022, 12:24 PM #2
Aftermarket injectors are great for holding paper down!
www.InjectorService.com
Call/Text - 204-326-0390
rgsauger liked this post
08-25-2022, 12:37 PM #3
You sure don't have to buy injectors from Mercury... https://kinsler.com/Shop/product-cat...efi/injectors/
08-25-2022, 02:32 PM #45000 RPM
- Aug 2010
- Jacksonville, FL
- 144
08-25-2022, 02:57 PM #5
08-26-2022, 12:34 PM #65000 RPM
- Feb 2004
- 122
- 20
- 12
- 85
- 61
08-26-2022, 04:11 PM #7
That is correct, but typically the part numbers only align with the OEM injectors (there are some exceptions). SO you have to replace with the same part number injector or you are playing with fire, unless that is you can remap the motor to match what you put in there.
If you know what you are doing you can put in another quality injector such as Injector Dynamics or FIC. But if the sole purpose is cost savings (which usually it is when we are having this discussion), then there is only 1 good solution. Buy a used set, and send them to me to be cleaned. or send the ones you currently have in. There is no such thing as a "cheap" injector.
stoker2001, CI STV liked this post
12-10-2022, 11:56 PM #8"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
260/280 fuel rail, injectors, regulator ... All O.E. Bosh Injectors Just Flow/Tested
By Pachanga_rick in forum Misc. Parts and AccessoriesReplies: 8Last Post: 10-05-2015, 10:01 AM -
OMC Tech: OEM VS aftermarket parts?
By drjerry1st in forum Technical DiscussionReplies: 3Last Post: 04-23-2010, 06:50 PM -
oem vs aftermarket
By k-man in forum Technical DiscussionReplies: 9Last Post: 03-21-2009, 02:00 PM -
Anybody have any experience with aftermarket injectors
By HowieDean in forum Technical DiscussionReplies: 0Last Post: 05-09-2002, 04:49 PM
