Results 1 to 8 of 8
    Aug 2010
    Jacksonville, FL
    Aftermarket injectors
    Has anyone had experience with aftermarket injectors? The price seems too good to be true. Is it worth the risk?
    1986 Baker 18 Mod VP, Yamaha 175
    2001 Crest Pontoon, 150 Opti
    1968 Sears 14' aluminum, Merc 110
    Nov 2019
    Canada
    Aftermarket injectors are great for holding paper down!
    www.InjectorService.com
    Call/Text - 204-326-0390
  3. Likes rgsauger liked this post
    You sure don't have to buy injectors from Mercury... https://kinsler.com/Shop/product-cat...efi/injectors/
    Aug 2010
    Jacksonville, FL
    Quote Originally Posted by InjectorService View Post
    That's what I was thinking. Mercury injectors are cheaper than a rebuild.
    Quote Originally Posted by bakerfreak View Post
    Mercury doesn't make fuel injectors... they buy them from people like Bosch, mark them up 1000%, and put them in a Mercury box.
  7. Likes sonicss33, stoker2001, rock liked this post
    300x
    Has anyone bought injectors for a 300X from them with good results?
    Nov 2019
    Canada
    That is correct, but typically the part numbers only align with the OEM injectors (there are some exceptions). SO you have to replace with the same part number injector or you are playing with fire, unless that is you can remap the motor to match what you put in there.
    If you know what you are doing you can put in another quality injector such as Injector Dynamics or FIC. But if the sole purpose is cost savings (which usually it is when we are having this discussion), then there is only 1 good solution. Buy a used set, and send them to me to be cleaned. or send the ones you currently have in. There is no such thing as a "cheap" injector.
  10. Likes stoker2001, CI STV liked this post
    Folsom, Cal
    noticed they are selling 2.5 racing "hose type" for $90 which is a smoking deal compared to Mercury prices..when i talked to Justin @kinsler he told me they were out of stock last summer and being they are obsolete now.
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  1. 260/280 fuel rail, injectors, regulator ... All O.E. Bosh Injectors Just Flow/Tested
    By Pachanga_rick in forum Misc. Parts and Accessories
    Last Post: 10-05-2015, 10:01 AM
  2. OMC Tech: OEM VS aftermarket parts?
    By drjerry1st in forum Technical Discussion
    Last Post: 04-23-2010, 06:50 PM
  3. oem vs aftermarket
    By k-man in forum Technical Discussion
    Last Post: 03-21-2009, 02:00 PM
  4. Anybody have any experience with aftermarket injectors
    By HowieDean in forum Technical Discussion
    Last Post: 05-09-2002, 04:49 PM
