Results 1 to 6 of 6
    Aug 2022
    New york
    26 and 27” trophy plus 14 3/4 diameter 4 blade
    Need for 2021 -115 mercurcury pro xs.
    call asap have cash in hand
    646 235-9546
    Knoxville tn
    I got a 27 trophy. That has been worked
    By dah propellers. Got it and wind up changing my motor. It's a 9/10. If your interested.
    Aug 2022
    New york
    A 27 trophy I just tried is too much pitch I can’t plane off. Is your 27 a stock diameter?
    if not what was it cut down to?
    is your 27 pitched down to a 26 ?
    please let me know
    thanks
    Dwayne
    Jan 2021
    Grand Junction Colorado
    26" trophy
    Quote Originally Posted by Biel13 View Post
    646 235-9546
    If you are still looking I have a 26" trophy but is only 14" dia.
    Jul 2013
    Never heard of a 14-3/4” diameter trophy
    Jan 2020
    Pinole, Ca
    For the 2021 proXS they come in 4-1/4 gearcase and 4-3/4 gearcase (command thrust).
    If you have a command thrust pro XS then you do in fact need a 14+ inch prop. They never made a 14-1/2 or 14-3/4 trophy. The trophy was a <14" prop for 4-1/4 gearcases (although a lot of people put them on bass boats with 4-3/4" gearcases to promote slippage out of the hole.
    You probably want to revise your post based on this info so that you are searching for a prop that mercury actually makes still? Maybe?
  1. Measuring diameter of a 3 blade??
    By astro@ptd.net in forum Props, Setup, and Rigging
    Last Post: 08-31-2011, 05:34 PM
  2. 4 blade trophy for a 2.5
    By beauler in forum Technical Discussion
    Last Post: 04-30-2002, 10:42 PM
  3. Who makes the largest diameter 4 blade thru-hub?
    By Hunter in forum Technical Discussion
    Last Post: 02-05-2002, 07:34 AM
