Results 1 to 15 of 17
    Jul 2020
    kentucky
    How to access Viper transom without splitting boat or cutting splashwell?
    My gelcoat is too nice to cut into the splash well. I would never match the metalflake. Is it possible to grind out transom from under the splash well and do a good job at replacing transom? I have only seen split hulls and cut splashwells done.
  2. Thanks bbezok thanked for this post
    Likes bbezok liked this post
    Jun 2018
    Floating around
    Most likely not possible. The top of the transom is laminated between the rear skin and the splashwell. That would be tough to get out although not impossible, i just cant imagine trying to do that. You could probably use corebond and make some offset question mark type transom pieces to slide in. Use lots and lots of corebond. The inner part of the transom under the splashwell would be easy enough but getting all the wood out of the top would be quite a challenge and designing transom core to be effective and fit in there would be super tricky. Not impossible just not practical imo.
    Well....if you're stupid and want a stiff neck for six months.....I know a guy.....
  5. Thanks bbezok thanked for this post
    Jun 2018
    Floating around
    My hat goes off to you on that one. Stiff? I think id go perma neck spasm if i crawled under there and tried that. Why am I not surprised you of all here are the one who took the hard road, and still won the war
  7. Likes rgsauger, bbezok liked this post
    Jul 2020
    kentucky
    Thanks, I am really wanting to avoid splitting that hull. Is the metal channel available or something similiar. I don't like the black rubber bumper despite its utility.
    Quote Originally Posted by 78vking View Post
    If you mean the rub rail, no it's not available. Some people have bought a junk boat just to get a few pieces.
    Houston, TX
    damn. Great signature about Bud, TS
  11. Thanks transomstand thanked for this post
    Likes LakeFever liked this post
  12. #8
    Minneapolis MN
    I would say thats nearly impossible. You're probably best off taking it out the top similar to what transomstand did. That will affect the least amount of gel coat. It's a 40 year old boat, going to have a few scars from being fixed.
  13. #9
    Mar 2004
    Brooklyn Park, MN
    I still want to do a chainsaw transom removal!!!! bring it to MN so I can fire up the Stihl!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. Likes VkingMike, sonicss33, OnPad liked this post
  15. #10
    Jun 2018
    Floating around
    Was thinking if you could get the rotten wood out from below you could lay in a fresh one to the bottom of the splashwell and use seacast to pour in the top part through a smallish hole or three on the cap. Might be doable and not damaged much gel
  16. #11
    Jul 2020
    kentucky
    Discovered it can't be done
    So if anyone is interested, it can't be done because the upright rear portion of splash well is bonded to transom. Maybe this is not original manufacture as mine had evidence of prior repair.
  17. Likes LakeFever, tnelsmn liked this post
  18. #12
    Mar 2023
    SW Florida
    good. you did it right. for those of you who are thinking of shortcuts on your transom. picture the jolly green giant swimming up behind your boat and hooking his fingers over the transom and jamming his thumbs into the back. then he picks your boat out of the water and starts shaking it as hard as he can. that is what your 20 to 350 hp outboard (sterndrive too!) is doing to your boat every time you hit the gas. now, i ask you, do you really wanna pour in seacast?
  19. #13
    CAN'T????? Hmmmmmm. And that is original manufacture, they are all bonded.
    Mar 2023
    SW Florida
    It can be done. Just not with keeping all the original finished surfaces intact.
  21. #15
    Quote Originally Posted by derekfl View Post
    If you were crazy enough, you could do it and keep everything intact.
  22. Likes XstreamVking liked this post
  1. Any help with transom to splashwell joints?
    By rujr in forum General Boating Discussion
    Last Post: 05-29-2011, 01:11 PM
  2. Cutting transom to 15"
    By rock in forum Fiberglass and Composites Discussion
    Last Post: 02-14-2011, 09:43 PM
  3. Cutting transom hole
    By ringstad in forum Technical Discussion
    Last Post: 05-02-2009, 11:41 PM
  4. splashwell/transom cracks
    By ptt in forum Fiberglass and Composites Discussion
    Last Post: 07-08-2007, 03:53 AM
  5. transom access plate needed on stv
    By stvhelm in forum General Boating Discussion
    Last Post: 03-12-2003, 05:00 PM
