Results 46 to 60 of 60
05-29-2023, 03:29 PM #46Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
Thanks for finding that. I had it about a year ago and then closed it out and forgot about it and then I couldn’t find again. So good find there.
I now have WH-46’s (in addition to the WH-22’s), which are correct for the late 1990
2.4/200 powerhead.
Any info on how to set the knob on cold start enrichment valve? My newer ones do not have that knob.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
05-29-2023, 04:04 PM #475000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
open it again and add to bookmarks or download it to documents...
05-29-2023, 04:45 PM #48Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
05-31-2023, 11:23 PM #49Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-01-2023, 06:37 AM #50
didn't look back to see what you posted! I'm thinking any knob is just for manual enrichment in the event of solenoid or electrical failure, should be closed for normal operation! clockwise
pcrussell50 thanked for this postpcrussell50 liked this post
06-01-2023, 09:31 AM #51Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
Second-to-last post of previous page… here.
Thanks for the insight. That was going to be my guess too… to start off fully clockwise/closed and see what happens. I just wasn’t sure if that setting would shut off enrichment fuel altogether even with the solenoid open. Sounds like it won’t, based on your input.
Is there a way override or manually enrich in the event of solenoid failure with the newer style enrichers that don’t have a knob?
__________
the wet:
the dry:
2003 bmw ///M5
06-01-2023, 11:22 AM #52
The enricher in picture is 80's crap. I would find an enricher that is activated with a solenoid by pushing in on key. Helps on initial startup . hold in for 5-8 seconds on cold start.
06-01-2023, 03:10 PM #53Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-02-2023, 12:01 AM #54
[QUOTE=bullet123;3390386]The enricher in picture is 80's crap. I would find an enricher that is activated with a solenoid by pushing in on key. /QUOTE]
it does... it's 'lectric to.'' just an older version.Last edited by tlwjkw; 06-02-2023 at 12:06 AM.
06-02-2023, 12:26 AM #55
06-02-2023, 06:00 AM #56
best to take the output fuel line off the enrichener for a test when running to make sure it's not adding fuel when not needed! pretty hard to tune a motor when a bad enrichener is bleeding fuel in as well!
maybe sqeezing primer bulb with line off primer might be a place to start!
06-02-2023, 12:37 PM #57Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-05-2023, 06:56 PM #58Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
How different and how much performance penalty would there be if I dropped my 2.4/200 onto the exhaust plates and tuner from a 2.0/150*. For Fishmotor/recreational use, not racing. I’m guessing that for puttering around with the wife and kids and a little skiing and tubing, it might be impossible to tell the difference by the seat of the pants.
Thoughts?
*I have the proper 2.4 tuner and plates… In our other house, where it will be a month or so before I can fetch them to this house.
__________
the wet:
the dry:
2003 bmw ///M5
06-05-2023, 11:19 PM #59Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
OK so going back to the studs… I ordered some fresh ones from ProMarine. Based on the photos they come with that maroon colored thread locker paste on the threads that go into the block. Thinking I should chase out the threads in the block and clean them with some acetone or lacquer thinner, so that the thread locker on the new studs can do it’s job.
This will be strictly a fresh water motor?
Sound like a plan? Or should I be worried about the studs freezing in place even in fresh water if the studs are put in dry?
__________
the wet:
the dry:
2003 bmw ///M5
07-05-2023, 11:46 PM #60Team Member
- May 2009
- 1,878
- 557
- 76
- 636
- 301
- 6 Post(s)
Well shoot. I was sure the the backyard motor flipper I bought this 2.4/200 off of had just put cheap Chinese electrics on for a quick sale, so it would run on the muffs, which it did, and blew 120 exact on all six.
Well, now I've had it all apart, it looks like it's all good stuff. The stator is CDI, and practically brand new. The switchboxes are both "Made in Germany" Sierras. Though one is newer than the other. (I thought the newer one was Chinesium. But the upon closer inspection even the newer one is. Sometimes you get lucky.
Pretty happy camper here.
__________
the wet:
the dry:
2003 bmw ///M5
Frankenstein promax
By thunter764 in forum Outboard EnginesReplies: 9Last Post: 06-03-2020, 09:01 PM -
Can you identify this frankenstein?
By Ski Machine in forum Technical DiscussionReplies: 4Last Post: 07-11-2014, 10:33 AM -
Mercury Tech: What is this Frankenstein and why won't it go???
By Motion22 in forum Technical DiscussionReplies: 4Last Post: 04-16-2014, 11:35 AM -
Frankenstein Typical Rat.
By Steve 1 in forum The Scream And Fly LoungeReplies: 2Last Post: 02-09-2009, 04:47 PM
