Results 16 to 30 of 60
10-20-2022, 06:47 AM #16
WH-22 came on 2.4 200s until 90 or 91 if memory serves me right
pcrussell50 thanked for this postpcrussell50 liked this post
10-20-2022, 06:48 AM #17
One of the best carbs IMO, 2nd only to WH 46s
pcrussell50 thanked for this postpcrussell50, Smalltownbassin liked this post
10-20-2022, 01:41 PM #18Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
10-20-2022, 01:42 PM #19Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
10-20-2022, 01:49 PM #20
The 46s were on 2.4 200s also. Both carbs work well on 2.5 motors when jetted properly. Lot of racers used them.
pcrussell50 thanked for this postSmalltownbassin, pcrussell50 liked this post
10-20-2022, 01:55 PM #21
The only 2.5 200 carb worth messing with is wmv-18
10-20-2022, 02:36 PM #22
Dont forget that 2.4 200s also used WH-18s lol. Dang engineerds were on one back then HAHA! I think the 2.4L was always just an experiment in power to weight ratios until they figured out that the fat block (2.5L) was the ticket. You think getting info on 22s is hard? Try asking about 18s lol! Crickets. I know several guys that run 22s on HIPO 2.5L though. They call them big barrels compared to other WH bodies because the throat is larger. Pretty sure 20s are the same. I do always keep going back to try tuning WMV-18s but always give up and put the 46s back on. Maybe the WH-18 bodies can perform. We will see.
10-20-2022, 02:49 PM #23
The SST 120 motors came with 46's with baffles and slosh tubes(except the later ones with the pumper carbs). Great carbs
10-20-2022, 05:07 PM #24Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
Any issues with picking out the correct sized carb gaskets? I have some from my 150 that are a little small in the main holes. I was thinking of cutting them out a little bigger. :shrugs:
Reason I ask is that neither Crowley or marineengine, do they even acknowledge the existence of the WH-22.
-PeterLast edited by pcrussell50; 10-20-2022 at 05:09 PM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
10-20-2022, 05:32 PM #25
I dont know man. Im sure someone can tell you.
10-20-2022, 11:32 PM #26
My 1990 carb V200 2.4 came with wh46’s
10-21-2022, 12:18 AM #27Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
10-21-2022, 03:10 PM #28
WH20 & 15's have the cast #1386-7598 considered Lg bore and came on the 81 225 7 pedal fishin motor.
WH22 & 46's and I think all Wh carbs that came from mother Merc 150-200's had the cast #1374-5427.
The 135hp Black Max fishing motors came with the smaller venturi carbs to make them a 135. Don't have cast #'s
My roundy round boat started with I think Wh27 because they came on my 2L.
Went to Wh46's because I found a set that had slosh tubes once I figured out, I wasn't turning hard enough.
Venturis are the same size don't quite understand holes in the butterfly's, probably for idling or initial acceleration.
Try your 22's against another set and lets us know if you can tell the difference.
11-01-2022, 02:51 PM #29Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
So I just ordered a set of WH-46's from the Canadian who had a really clean looking set of them off eBay. They were taken off a 2.5/200. I plan to use them on my 1990 2.4/200, which apparently also used WH-46's.
What is the likelihood that they both use the same jetting?
Also, is there anything else I should look out for in using these on my 2.4/200 since they came off a 2.5/200?
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
11-01-2022, 03:18 PM #30
something is wrong, WH 46 did not come on 2.5, that I know of.
1973 Viper - sold
1978 Viking - sold
1995 XB02
pcrussell50 thanked for this postpcrussell50, bullet123 liked this post
Frankenstein promax
By thunter764 in forum Outboard EnginesReplies: 9Last Post: 06-03-2020, 09:01 PM -
Can you identify this frankenstein?
By Ski Machine in forum Technical DiscussionReplies: 4Last Post: 07-11-2014, 10:33 AM -
Mercury Tech: What is this Frankenstein and why won't it go???
By Motion22 in forum Technical DiscussionReplies: 4Last Post: 04-16-2014, 11:35 AM -
Frankenstein Typical Rat.
By Steve 1 in forum The Scream And Fly LoungeReplies: 2Last Post: 02-09-2009, 04:47 PM
