Results 1 to 4 of 4
    Oct 2019
    Finland
    Bunch of problems in Johnson GT300
    Hi,
    Engine starts sometimes with all cylinders but when you start taking it to the plane it drops one cylinder off and it stays like that. All revs stops in 2200rpm with gear on. With neutral it sometimes gets full revs after turning key off and on.
    Yesterday i also noticed that it wont charge anymore and that was a new problem. I have worked all ****in summer to get motor scream but no no no.......first i cleaned all carbs because it seemed that it was gasoline problem and ofcourse there can be that problem too still...everything has been cleaned and onetime.it has been on plane and worked 10min, then everything off stopped and started after 5mins. Have changed plugs, checked spark, checked coils, checked leaks on gasoline side but no, it will ****in limb all the time.
    I also added electric gas pump to make sure it gets gasoline because it one time worked fully when i drove and buddy pumped with the bulp....
    Please give me some advises🤷*♂️
    7 Post(s)
    Link and sync.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    May 2002
    Victorville ca.
    Make sure your shift linkage is set correct. I have had the shift interrupter cause the engine to drop 4 cylinders.
  4. Likes David - WI, Baker343, racer, rgsauger liked this post
    Jan 2003
    aalsmeer
    Maybe start with a fresh set of spark plugs when it runs
    You might be able to see what the problem cylinders are and search more focused
    NGK BR8-HS10
  1. Johnson/Evinrude V8 GT300 Parts
    By atclen in forum Misc. Parts and Accessories
    Last Post: 01-17-2017, 09:33 PM
  2. 1985 Johnson GT300
    By atclen in forum Outboard Engines
    Last Post: 01-03-2016, 01:32 AM
  3. 92 Johnson GT300
    By AzAvenger in forum Outboard and Racing History
    Last Post: 07-22-2015, 09:39 AM
  4. OMC Tech: johnson gt300 wot timings
    By teamboatracing in forum Technical Discussion
    Last Post: 03-17-2014, 10:57 PM
  5. any one want a CHEAP gt300 johnson??
    By wing nut in forum General Boating Discussion
    Last Post: 02-28-2003, 03:22 AM
