Results 1 to 4 of 4
    Mar 2020
    netherlands
    Fletcher arrowsport 16 with 150 hp XR6
    Recently finished my transom and mounted my new engine. The boat is a 16 ft Fletcher arrowsport and is originally rated for 90hp.
    I installed a 6 inch hydraulic jackplate.
    First run i reached 98kmu / 60mph
    The propellor is used is a revolution4 23p. Huge prop compared to a Laser2. Very poor out of the hole and wont rev up (and get up on plane) with 3+ people, even with all PVS plugs removed. But once it runs, it runs nice.
    As i said, 98kmu / 60mph @ 5800rpm
    The boat becomes wobbly at those speeds and start chine walking, but i can correct it with steering.
    And i can throw a rooster tail, which i think is cool. Any recommandations for props?
  2. Likes rgsauger liked this post
    Lake Coochiching, Ontario
    I always tell people to start with a used Trophy. 4 blades will help with the chinewalk. But maybe Trophies are not so available/cheap in your area.
    You are at 11% slip if you have the standard size 1.87 ratio gearbox. Not bad.
    Mar 2020
    netherlands
    I read online that the trophy 4 was comparable with the revolution 4. I will try to find a trophy4.
    Chinawalk is not so bad at the moment.
    Btw, update on speed: i reached 103kmh / 64mph with same prop and lots of positive trim
    If you have the standard 4.75" gearcase and an even pitch Trophy, there will be a gap between the gearcase and the prop that will allow more gas over the prop. If you have the 4.25" gearcase you will have 1.78 gears and no gap - worse for holeshot
  1. Fletcher 16 arrowsport transom restauration
    By killerpirate in forum Boat Build-Ups and Restorations
    Last Post: 05-04-2022, 06:51 AM
  2. Want to put a PAD on Fletcher!
    By bigboy in forum Fiberglass and Composites Discussion
    Last Post: 09-18-2006, 12:51 PM
  3. Do you still remember my fletcher?
    Last Post: 10-28-2005, 10:18 AM
  4. Project Fletcher
    Last Post: 07-07-2005, 10:59 AM
  5. Fletcher experiences!
    By bigboy in forum General Boating Discussion
    Last Post: 12-15-2004, 09:09 AM
