Results 1 to 5 of 5
Thread: Opitmax oil leak
08-06-2022, 08:25 AM #15000 RPM
- Feb 2004
- Tarpon Springs, Florida
- 123
- 7
Opitmax oil leak
Guys i have a 2015 250 opti leaking oil from somewhere while in use. It is not leaking from the cap and not leaking from the oil pump and not leaking from any of the lines on the side of the motor, It appears to be coming out of the lower intake. Any ideas ? It's enough oil to come out at the back of the motor lower cowl.
08-06-2022, 09:23 AM #2
My bet is from the oil pump. Put your finger under the pump. There will probably be a drop of oil there. If it is it is the o ring sealing the front half of the pump.
08-06-2022, 10:45 AM #3
08-06-2022, 12:03 PM #45000 RPM
- Feb 2004
- 123
- 7
Nothing under the oil pump dry as a bone. I brake cleaned everything so i could find it but it appears as though its under the intake
08-06-2022, 12:05 PM #55000 RPM
- Feb 2004
- 123
- 7
if it is the intake manifold gasket, why is there oil coming out of it ? Shouldnt all the oil be going in the motor ? I could see maybe a small amount but i wouldnt call this a small amount. it's enough to make it to the lower unit
2.5 L 175 hp opitmax to 200 hp ?
By Narcoholic in forum Technical DiscussionReplies: 0Last Post: 09-10-2020, 07:44 AM -
mercury opitmax pressure gauge kit
By suzbass10 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 05-22-2017, 10:15 AM -
Opitmax 225
By jmatsuoka in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 06-28-2013, 08:17 PM
