Results 1 to 9 of 9
    Jul 2005
    Rebuilt Mercury 300 Promax Drop on powerhead (Ported by Chaz)
    Freshly rebuild 300 Promax
    Exhaust chest ported
    Liners removed to gas flow all the transfers
    once removed, liners were ported (exhaust, transfer and inlets) before refitting and port matching to block
    Front half cut and counter bored to increase crankcase compression
    Rod slots opened up and gas flowed
    All oversize pistons 2xBrand new ones in the bottom, the rest were replaced less than 20 hours ago when the motor was first built.
    Cylinder heads cut to 57cc which will hapily run on Pump fuel
    Weight matched Rods (end to end balanced too)
    Lightweight flywheel
    Injector have been cleaned and are all within 2 CC's
    New spark plugs, cleaned regulator screens, all bleed pipes replaced,
    Reed cages have been linished perfectly flat and fitted with CCM Reeds
    Never had any holes or welds in the block
    300 Promax ECUs with 7000 rpm limiter
    This is an awesome powerhead which owes me a small fortune. Its not seen fuel since being built so will require running in. I have loads of pictures of the machining and build process if you'd like to see how much work went into it.
    Asking $5750 as a drop on powerhead ready to go
    located in England but have shipped engines, boats, mids etc all over without problem
    Attached Thumbnails Attached Thumbnails IMG_20220724_123802.jpg   20220802_121434.jpg   20220802_121331.jpg   20220802_121144.jpg   20220802_121138_001.jpg
    Jul 2005
    internal work
    Attached Thumbnails Attached Thumbnails 20130615_180602.jpg   boostslot_zps9a5bd444.jpg   Cleaned_zpsd184883b.jpg   cyltop_zps83852a79.jpg   20130615_175924.jpg
    Jul 2005
    Price dropped!
    Jul 2005
    Bump
    Jul 2005
    Price droped to 5250 usd!
    Jul 2005
    Bump
    Apr 2021
    Ontario, Canada
    PM'd you. Hit me back.
    Jul 2005
    Preliminary sold. Thanks scream and fly
    longisland
    Quote Originally Posted by MaDneSS View Post
    internal work
    did you weld it shut again or did you make a removable back plate??
  1. Replies: 1
    Last Post: 03-21-2015, 09:19 AM
