Results 1 to 3 of 3
    Jul 2021
    Pompano Beach
    Does a prop for a Bravo sterndrive fit on a 300r torquemaster? pressed in hub.
    I have a 300R torquemaster and aside from knowing it's a 1.25" shaft, is a propeller from a bravo sterndrive with pressed in hub directly compatible? WHat IS compatible to the torquemaster? Is the 1.25" considered a fat shaft? How many splines?
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by Capt j View Post
    No, that torquemaster is mercury fat shaft (19 spline) and will not fit a pressed in bravo hub prop unless someone put in a fat shaft hub kit in it. Most bravo 1s and 2 drives had small propshafts, but the 1XR had the fat shaft I know that. Most bravo model props have a small shaft hub pressed in or are flo-torq
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Aug 2013
    Oshkosh, WI
    Mercury hasn't made props with pressed in hubs (aside from small 40-60hp choppers and cleavers) in 20 years. Any Bravo I, Tempest, etc has a blank bore and you choose which Flo Torq hub kit goes into it. If the prop in question has a square bore, you can remove that hub kit and replace with whatever you need.
    2003 Triad RR 280 ROS
  1. Nose cone a 300R torquemaster?
    By simpson_3 in forum General Boating Discussion
    Last Post: 05-09-2021, 09:23 PM
  2. Is Anyone Running a Max 5 Prop On Sterndrive Here?
    By Donzi222 in forum Props, Setup, and Rigging
    Last Post: 10-23-2020, 02:33 PM
  3. Prop advice for a sterndrive
    By gregpro50 in forum Props, Setup, and Rigging
    Last Post: 06-05-2011, 10:24 AM
