Results 1 to 14 of 14
Thread: 260 Flywheel Questions
08-02-2022, 06:21 AM #1
I've searched, but the results have come up a bit foggy still.
I picked up a 260 lighter weight flywheel and am wanting to convert from 40amp. I currently just have the flywheel, so is it just the stator and regulator setup that need to be changed to make all this work? I run zero electronics, so I am not worried about less amperage.
08-02-2022, 08:22 AM #2
just need the 16 amp stator to swap out. Then just need to get the regulator and rectifier figured out, if you even need it. Are you running the pulse pump or electric pump? What kind of battery (AGM or led acid)?
1973 Viper - sold
1978 Viking - sold
1995 XB02
08-02-2022, 12:37 PM #3
08-02-2022, 12:56 PM #4
rjdubiel liked this post
08-02-2022, 12:57 PM #5
I would suggest running a regulator but not completely needed with a lead acid as that battery can gas off when overcharged. AGM batteries get damaged from overcharging and must have a regulator in my opinion.
1973 Viper - sold
1978 Viking - sold
1995 XB02
25two.stroke liked this post
08-02-2022, 01:12 PM #6Team Member
- Sep 2008
- Dow, IL \ Theodosia Mo.
- 297
- 17
- 87
- 51
Will a 16 amp stator even charge can AGM battery? CDI says lead acid only.
08-02-2022, 02:06 PM #7
yes, but it may overcharge with a carb motor and no other electrics going and may damage the AGM battery. I think that is why CDI says that as they don't want to be pegged with damaging batteries with their products.
here it is.
https://issuu.com/cdielectronics/doc...ding_batteriesLast edited by rjdubiel; 08-02-2022 at 02:15 PM.
1973 Viper - sold
1978 Viking - sold
1995 XB02
08-02-2022, 02:54 PM #8Team Member
- Sep 2008
- 297
- 17
- 87
- 51
Im battling one now that wont charge with agm battery. Have tested everything and tried new stator and rectifier. Only thing left is flywheel or battery. Next step is lead acid battery.
08-02-2022, 03:09 PM #9
When the motor is running see if you have charging voltage at the battery. I am guessing you AGM battery wont take the charge, not the charging components are bad on the engine.
1973 Viper - sold
1978 Viking - sold
1995 XB02
08-05-2022, 03:58 AM #10
08-05-2022, 05:46 AM #11
08-05-2022, 07:39 AM #12
VkingMike thanked for this post
08-05-2022, 12:37 PM #13
CDI Electronics is # 5456 for the 9 amp and 5456-16 for the 16 amp.
08-10-2022, 12:02 PM #14
mercury hi perf flywheel timing indicator alum part, sits up next to flywheel, 2.5 li
By rl in forum Misc. Parts and AccessoriesReplies: 7Last Post: 02-01-2023, 05:11 PM -
Mercury Tech: flywheel, stator, trigger questions
By Deznuts3570 in forum Technical DiscussionReplies: 7Last Post: 05-01-2015, 03:10 PM -
Questions about water cooled manifolds; why? Newb questions.
By Cash68 in forum General Boating DiscussionReplies: 5Last Post: 05-28-2010, 11:31 PM -
OMC Tech: Flexplate flywheel, external alternator, MSD ignition combo questions.
By HydraSports in forum Technical DiscussionReplies: 15Last Post: 11-12-2009, 11:15 PM -
2.0 and 2.4 flywheel questions
By jay1 in forum Technical DiscussionReplies: 2Last Post: 05-07-2008, 06:57 AM
