Results 1 to 7 of 7
Thread: HPDI Rebuild Issues
08-01-2022, 08:04 AM #1New Member
- Jul 2022
- Texas
HPDI Rebuild Issues
I got my motor rebuilt high-pressure fuel pump rebuilt injectors sent off and professionally cleaned. My mechanic says it will IDLE great while trimmed up but as soon as he trims down it sputters and dies.
Lots of suggestions from guys in the know
Link an Sync, Clean an Replace filter in VST, LP fuel pump replacement, kinked fuel hose. Is there anything else I’m missing. Making a list for mechanic for things to check before I have to bring to dealer. Thanks for the info
Andrew
08-01-2022, 09:06 PM #2
Welcome to scream and fly. Help will be along shortly. I’m a carb guy. Sorry
08-02-2022, 11:40 AM #3New Member
- Jul 2022
- Texas
Fixed isssue in VST. Went out and tested won’t rev above 3 k on 4 cylinders in forward but wil runs on all 6 in reverse and revs up. His software bit the dust waiting on replacement. Said he replaced Netutral safety switch and Shift position switch. Thanks
08-10-2022, 11:07 AM #4Junior Member
- Mar 2011
- Texas
08-15-2022, 11:39 AM #55000 RPM
- Dec 2008
- Coldspring, TX
- 114
- 13
- 28
Sounds like the shift switch is not adjusted correctly and not allowing the computer to recognize forward gear. Could be as simple as the shift cable adjustment. Does it want to grind when shifting into forward and not reverse?
09-16-2022, 09:46 AM #6Junior Member
- Mar 2011
- Texas
No grinding. Thinks he has it narrowed down to bad TPS, Installing tomorrow
10-28-2022, 09:03 AM #7Junior Member
- Mar 2011
- Texas
Looks like it's down to the ECU hopefully I'm out of $$$
225 HPDI rebuild
By FORBESAUTO in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 143Last Post: 06-18-2022, 04:31 AM -
Yamaha Tech: 2003 250 hpdi running on 4, no injector responce in tests on cyl 2 or 5+ more issues
By 150aintenuff in forum Technical DiscussionReplies: 6Last Post: 08-12-2011, 12:39 PM -
How do you stop Yamaha 200 hpdi VST issues?
By baja200merk in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 6Last Post: 07-23-2009, 02:14 PM -
175 Yamaha HPDI issues
By mikevolk in forum Technical DiscussionReplies: 6Last Post: 10-02-2007, 02:12 AM -
Yamaha HPDI V-Max Upper cowling clearance issues??? HELP!
By Over-Easy in forum Technical DiscussionReplies: 0Last Post: 06-28-2004, 03:46 PM
