Results 1 to 12 of 12
Thread: GPS antenna for smartcraft gage
07-30-2022, 07:31 PM #1Team Member
- Lake Coochiching, Ontario
- 7,769
- 276
- 487
- 1592
- 6 Post(s)
I bought a Merc Monitor multi function gage in 2020 and the speedometer function has never worked. Usually I monkey with it for a while, give up, and just go boating. After this year's monkeying I now think the GPS antenna is not sending a signal to the gage. It would be nice to buy another antenna and plug it in, but the Merc antenna is almost $800 at best
Antenna part number 8M0091565
If I buy a non Mercury NMEA antenna, will my wiring harness plug into it?
Other than price, are there features that I should look for in an antenna?
07-31-2022, 10:49 PM #26000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
Non Merc GPS Systems
Anything "plug and play" compatible with SmartCraft can be $$$$. GPS speedometers are pretty straightforward. Instead of going the SmartCraft route I went with an independent Sierra GPS speedo with a Veethree antenna. Be careful with the Veethree pin connector diagram wiring. They are confusing to read. That was the only hang up with Veethree. Have you checked your antenna location? They don't receive satellite signals very well buried underneath fiberglass or metal structures. Surface mounts are best. I made a little weather "hat" for my antenna out of a fake carbon fiber car antenna fairing.
08-01-2022, 08:17 AM #3Team Member
- 7,769
- 276
- 487
- 1592
- 6 Post(s)
The antenna is under the deck of my SS2000. I know of a Grandsport with same antenna under the deck and that one works. But I could try moving mine. I went with the Merc Monitor as it can read mpg. I was curious what prop/rpm/speed would be most fuel efficient.
08-01-2022, 09:50 AM #46000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
08-01-2022, 05:36 PM #5
Try Livorsi. They might have something compatible with Smartcraft. RR
08-01-2022, 08:00 PM #6Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
is it standard nmea 0183, then you can check it with a laptop ( usb to serial adapter)?
08-01-2022, 08:31 PM #7Team Member
- 7,769
- 276
- 487
- 1592
- 6 Post(s)
It's not a USB connection. I can call a local Livorsi dealer and see what I can find out.
08-01-2022, 10:20 PM #8Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
08-01-2022, 11:31 PM #9
08-02-2022, 06:33 PM #105000 RPM
- Feb 2017
- Wixom lake michigan
- 177
- 40
- 9
- 293
- 34
08-03-2022, 07:02 PM #11Member
- Mar 2017
- Cordova il
- 90
I wired a basic antenna I ordered off Amazon around $30 2 years ago
it has to be NMES 0183 compatible
it’s way to wire up if u follow directions within smart craft manual
power and ground wire along with two signal wires from the antenna
08-03-2022, 07:03 PM #12Member
- Mar 2017
- Cordova il
- 90
Correction NMEA 0183
Smartcraft Gauges (NMEA 0183) Antenna Wiring Question
By wasvette in forum Technical DiscussionReplies: 2Last Post: 07-08-2016, 10:56 AM -
EGT Gage
By rude tim in forum Technical DiscussionReplies: 7Last Post: 10-28-2011, 08:50 AM
