Hi!
I installed 450R on my Phantom 25 last summer. It has Livorsi Vantage gauges, Merc Monitor and a Simrad 9" Go Plotter. The previous engine was a Verado 400R 2017 model.
All Livorsi instruments except Oil Pressure and Oil Temp are working (Trim, Voltage, Water temp, Boost, RPM, GPS, Fuel level, etc). The Merc Monitor also works on all type of info. incl Oil Temp and Oil Pressure. The same with the Simrad 9» GO plotter. All Livorsi gauges resets when I put the ignition on, but they do not read Oil Pressure, Oil Level and Oil Temp.
Do you know how to do to get Livorsi Vantage Oil Pressure and Oil Temp gauges to communicate with the New engine?
Cheeers, Toffen
