Results 1 to 15 of 15
    Mar 2004
    Brooklyn Park, MN
    Ridgeback lower mount spacers
    Looking to see if anyone has the thickness of the spacers of the lower mounting spacers needed on a ridgeback can? I think the part number is:23-42356 - SPACER,NLA
    thanks
    RJ
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jan 2020
    Pinole, Ca
    AS I recall when I took it apart there were 4 steel washers on each stud, so that was probably just over 3/8"
    See here theres 2 different spacers depending on stud length
  3. Likes rjdubiel liked this post
    Mar 2004
    Brooklyn Park, MN
    Thank you. It looks great by the way! I have the washers in there now to get it on the clamp but will make an aluminum spacer.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  5. Likes tnelsmn, LakeFever, Baker343 liked this post
    Jan 2020
    Pinole, Ca
    DAAMMMMNNNNN that does look good. Love the blue, love the ridgeback with the 260 cowl, and love whats hiding underneath!
  7. Likes LakeFever liked this post
  10. Likes LakeFever, Baker343 liked this post
  11. #7
    Mar 2004
    Brooklyn Park, MN
    Will have some numbers for you soon as my next race is 8/13. Just need to keep her under 87 mph so I don't go too fast in the UMPBA Lake Racer 2 class (76-85 MPH with 2 MPH breakout, so max is 87.0 mph, 87.1 and you went too fast and lose that race).
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. Likes tnelsmn liked this post
  13. #8
    Florida Keys
    I made my own at 1/2” and they’re a tad too long, but it’s never been an issue….been running that way for 15 years. 3/8” is probably right on
    '95 STV "The Blue Goose"
  14. Likes rjdubiel liked this post
  15. #9
    Mar 2004
    Brooklyn Park, MN
    My stack of washers is exactly 3/8. I think I will run it like that a few times and pull the lower and see if it is waring the driveshaft splines.
    thanks again guys.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. #10
    Feb 2011
    HUDSON, FLORIDA
    I Dont see how the spacers alter drive shaft alignment? the mid still mates flush to pwr hd? with adptor plates as a unit.. am i missing something?
  17. #11
    Mar 2004
    Brooklyn Park, MN
    With no power head and just the 3 bolts at the back of the plate into the mid there is a little bit of play and the original spacers are not available so just trying to get it correct. I agree, would be hard to have it that misaligned as you stated, but I can mess chit up with the best of them!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. #12
    Feb 2011
    HUDSON, FLORIDA
    got ya. i had to add spacers, because when i tightened upper mounts [2 long bolts] the bottom plate[adaptor] wanted lift up at the rear.. like somethin out of square. maybe the ridgeback mid designed for a 1pc plate im thinkin. the added washers helped.
  19. Likes rjdubiel liked this post
  20. #13
    Nov 2019
    They are 3/8” thick
    Attached Thumbnails Attached Thumbnails DD7388B5-A76E-4C95-9D08-22BB4ECDDBF1.jpg   2D9BDBD0-78E6-4DE5-9BCA-FCEFE5051B11.jpg   961AEDD5-203D-4853-AD13-1DFB1536D825.jpg
  21. Likes rjdubiel liked this post
  22. #14
  1. 2000 225 Promax Injected premix 20" ridgeback Coned lower
    By vw-nut in forum Outboard Engines
    Last Post: 08-22-2020, 03:48 PM
  2. Lower Mount Spacers for Ridgeback?????
    By Sonik in forum Props, Setup, and Rigging
    Last Post: 02-19-2011, 07:16 AM
  3. Mercury Tech: Ridgeback OS Can: lower motor mounts
    By GamblerSS in forum Technical Discussion
    Last Post: 06-23-2010, 04:57 PM
