Results 1 to 13 of 13
07-18-2022, 12:00 PM #18000 RPM
- Oct 2011
- Southern California
- 3,567
- 179
- 471
- 3405
- 2330
- 29 Post(s)
When do you Gilde to a landing or deploy a Parachute?
07-18-2022, 03:24 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7149
- 3 Post(s)
Its a 100K decision to pull the chute on a Cirrus but all that have are still able to tell the story. There is no reason to die over a little bit of money. We lost friends that attempted a glide and caught wires with the landing gear. Glide ins are great if you are on a final but seldom do you have proper clearing within range of a power loss.
CDave, Lake X Kid liked this post
07-18-2022, 06:53 PM #3
Back when I worked offshore one of the pilots told me the Bell 206L glide ratio is better than a lot of small aircraft.
93 STV Mod VP/MERC 2.5 200
Proverbs 4:18-20
-- John F. Kennedy 1962
07-18-2022, 08:41 PM #4Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7149
- 3 Post(s)
One of the best glide patterns ever. These things were designed for the military with an unlimited budget. One of the nicest aircraft I have been able to use over the last few years thanks to great friend/client. He has a G5 but uses this and a King Air 350 for short trips. This thing makes property/site inspection trips much more enjoyable.
07-18-2022, 10:21 PM #5
No glide capability, is the problem I see with all the new personal flying devices being designed, based off of the quadcopter or something similar with no wing, or autorotatation abilities. I guess these devices will need a parachute, although wouldn't be very effective at low altitude.
07-20-2022, 02:20 PM #6
So guys help out a person who knows little about flying. I know some planes have chutes, I guess I saw videos where the plane was horizontal under the chute. Was the plane in the video coming down as designed, nose first, or was there a problem?
Per Rock:
"Once I bought my first Hydrostream boating changed forever for me."
Per my hero Instigator:
"I try not to let common sense interfere w/my boat buying decisions."
Pat Gent
cell 954-249-3246
'78 Hydrostream Vandal (being rebuilt)
'86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
07-21-2022, 12:21 PM #7
I have many hours in an old 152, Citabria, Scout, Cub, etc. Part of the training within the first 10 hours was to prepare for an emergency landing. Cut the power, trim for the best glide, fine a road, field, or other suitable OAL.
The plane is now junk. Yea, he walked away.... But it was a fail IMO. I was trained differently.
07-21-2022, 07:00 PM #8Member
- Mar 2022
- Florida
- 38
- 7
- 13
- 103
Totally agree- there is nothing you shouldnt already be prepped for as a pilot- Loss of engine power is one of many-
Does this system save lives- or at least lesson the loss of ? of course . Is it the answer - ??? I guess if you value life more than the aircraft-from inexperience - then your good.
Forkin' Crazy liked this post
07-24-2022, 10:12 PM #98000 RPM
- Oct 2011
- 3,567
- 179
- 471
- 3405
- 2330
- 29 Post(s)
The Center of Gravity is a big issue in flight. I remember flying into Memphis, and I had to take a (8 or 10 seater) to a smaller city airport. And the pilot asked me to seat in the back seat for CG balance.
Parachute placement-location in a small airplane is going to determine the CG descent angle. And passenger weight will shift the CG. That is why the R44 Robinson helicopter has a high/long mast to the rotors. So when passengers get inside (vs the pilot solo) the copter the bird's CG does not shift as much.
07-24-2022, 11:36 PM #10
I think the tall rotor mast is for stability. The "string" you are hanging from is longer, therefore more stable.
They run the piss out of them shooting hogs in Texas. I would love to do that! Just not this....???
07-24-2022, 11:51 PM #11
I saw that a while back. I think I read somewhere in the comments that he only had one out of two magneto turned on, oops!!
Not that I'm pilot of anything bigger than rc, I believe a parachute system has to be located wherever you have the room to put it. On most small craft it would be located behind cg or cockpit.
There's another video floating around, of a stunt plane losing half his wing, then deploying a chute, saving his bacon.
07-29-2022, 12:35 PM #128000 RPM
- Oct 2011
- 3,567
- 179
- 471
- 3405
- 2330
- 29 Post(s)
The longer distant pendulum has a higher Moment of Inertia (less sensitivity to movement), than a shorter distance.
Adding passenger(s) weight on a helicopter has less sensitivity to CG movement, when the pendulum distance (rotor head pivot-point to cabin/helicopter’s center of gravity) is longer.
Therefore, the longer rotor mast (pendulum distance) on a R44 Robinson helicopter.
07-29-2022, 02:30 PM #13
I know what CG is. Used to do a "weight and balance" when I worked at an FBO.
And I could balance this thing...
He don't need no stinkin parachute!
By XstreamVking in forum The Scream And Fly LoungeReplies: 4Last Post: 10-04-2019, 07:49 PM -
lifeline parachute jacket and matching bell helmet
By Baitman in forum Misc. Parts and AccessoriesReplies: 4Last Post: 08-10-2014, 07:49 AM -
Don't forget your Parachute. BAD DAY
By WILDMAN in forum General Boating DiscussionReplies: 7Last Post: 05-12-2006, 04:09 PM -
Anybody ever heard of using an emergency parachute to prevent landing upside-down?
By dma251 in forum Boating Safety and Safety EquipmentReplies: 1Last Post: 11-01-2004, 01:33 PM -
Parachute conversion
By tombrown in forum General Boating DiscussionReplies: 1Last Post: 07-06-2001, 08:59 PM
