Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
  1. #31
    Injector service do you go to the trouble of indexing injectors putting the higher flow injectors on specific cylinders?
    Sep 2020
    Mississippi
    Blake is really good
  3. #33
    Nov 2019
    Canada
    Yes I typically do, often depends on application and how far out from perfectly matched too.
    www.InjectorService.com
    Call/Text - 204-326-0390
  4. Likes XstreamVking liked this post
  5. #34
    Thanks for the great info you share
    May 2010
    Missouri
    Update: After lots of research, speaking to injector shops and guys like you, combined with my own tests on these DI’s, I decided to roll the dice and reinstall and Run’em.
    Had oil pump primed at a local shop and while having laptop plugged in, ran all engine parameters while it was running. Everything checked out fine. Took it to the upper end of the lake in the river system and ran it. No issues.
    Today it got beat on.. took it to the lake, w/ two of my teenage daughters, all their stuff, all my gear, an added heavy anchor, food / drinks /ice, 1/3 tank fuel in 100 deg air temp. Ran fine… a little slow out the gate with the weight and heat, but ran solid 70 all day. Glad I listened to Blake and didn’t piss away over $3k in injectors.
    ‘13 Triton 21HP DC, ‘13 250 ProXS, 25p Croxton B&B Tempest +,10” Atlas JP, dual poles, 4 heavy ass batteries, and lots of gear….
  7. Thanks InjectorService thanked for this post
    Likes David - WI, stoker2001 liked this post
  8. #36
    Sep 2017
    ontario
    Glad to here - he is knowledgable and tech support is strong - use him with confidence.
  9. #37
    May 2010
    Missouri
    Update: Added several hours to the engine and probably 100 miles. Running as good as it did when I bought it (used) and before I found the bad compressor. Still can’t hit the 77 mph tourney load I was told it would do.
    Sent Merc an email expressing my disgust of their Direct Injector price gouging. Received an email from them, basically saying (f’u) the prices are set by the distributors of the part. I responded that’s a lie because I know what the majority of shops pay for their parts. And, the majority of them only add shipping and a little bit of handling for storing the parts. They are not making $550 each on these air injectors. (If compared to Tohatsu / Nissan, which are same design at $200 ea). I reminded them that I found a manufacturers error that could have cost them millions,, but hey, not even a damn thank you from Merc.
  10. #38
    Nov 2019
    Canada
    Priced out new ones today..... $1000 CAD EACH! Unreal.
  11. #39
    May 2010
    Missouri
    Quote Originally Posted by InjectorService View Post
    WOW… damn ridiculous
  12. #40
    Jan 2020
    Pinole, Ca
    And most dealers don't even add shipping+handling for stocking parts. Most.
    When they say the prices are set by the distributors of the parts they probably meant their suppliers, not the local dealers? Maybe? I know mercury does set the retail price on all parts, and all dealers have the same retail price. The dealer cost on parts varies a little bit, so profit/markup varies. But the end retail price is the same for all dealers unless they choose to give you a deal.
  13. Likes David - WI, stoker2001 liked this post
  14. #41
    Aug 2022
    Pennsylvania
    send them up here ill test em and clean them
  15. #42
    May 2010
    Missouri
    Bottom line, Mercury is ripping folks off.. Direct Injectors are just one of many. Look at Opti thermostats, $125 ea.. well,, nope,, found them for $30,, but they don’t come in a package with a $95 “Mercury logo”
  16. Likes David - WI liked this post
  17. #43
    Nov 2019
    Canada
    Quote Originally Posted by Evans.larry1997 View Post
    Hey, welome to the Scream N Fly site. Just a heads up, if you want to start advertising or selling services you should get in contact with the site owner Greg first to become a supporting vendor.
  18. #44
    Sep 2006
    Key Largo, Fl
    This+++
  1. Optimax injectors
    By skatermike24 in forum Parts Wanted
    Last Post: 06-24-2015, 04:34 PM
  2. Optimax air injectors?
    By xr6 in forum Technical Discussion
    Last Post: 03-14-2010, 08:24 PM
