Results 1 to 11 of 11
    Jul 2022
    Virginia
    LS Swap sidewinder
    https://youtube.com/shorts/Y2ZDzcAefRg?feature=shareClick image for larger version.
ID:	507259Hey guys I'm new to the boating scene I'm looking for some insight I have a 16 Ft. sidewinder I ls swapped it has a alpha drive on it with a shower I ran 73mph at 5500 rpm with a 4 blade 21p started to chime walk around 68mph from what I've read so far that I'm pushing the limits on the hull..... I've considered blueprinting the hull during the winter time but not so sure it would be worth it or try to find another hull to swap everything over to.... due to my lack of knowledge I'm hitting a wall to keep going with this hull or look for another hopefully a hull with a bravo drive since I'm already past my limits on the alpha drive.
  2. Likes LakeFever, rgsauger, winderman, 89LASER liked this post
    Jul 2022
    Virginia
    thank you I will look into it.
    Jun 2018
    Floating around
    Cool build, post some pics. With above its mostly outboards around here but i would also agree your past the limits of fun with that hull. A glastron carlson I/O would make a nice swap candidate. Heres a fast one
    https://m.youtube.com/watch?v=hUZUi5DuDVQ
  5. Likes Dustinlorey, CharlieN liked this post
    Jul 2022
    Virginia
    Yes I'm starting to realize that I'm in a weird category not a jet drive and not a big offshore boat and not a small outboard boat
    Jun 2018
    Floating around
    I know a guy with a Canadian made Charger that had an I/O small block chevy. That thing ran hard, certainly scared the snot out of me back in the day
  8. Likes Dustinlorey liked this post
    Jul 2022
    Virginia
    I posted a pic and vid of the first time out above in first thread
    Jun 2018
    Floating around
    Sounds great! Cam sounds lumpy
    East Wallyworld Vt
    Late to the party here, if I am correct the Sidewinder hulls I am aware of had rounded keels.
    Back in 2015 I added a pad to a 20' Glastron to change its character. It defiantly made a difference but I do not consider I am done with it, just have not gotten back to it.
ID:	518903 Click image for larger version.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  12. Likes LakeFever liked this post
  13. #9
    Quote Originally Posted by Dustinlorey View Post
    ...part of the problem is the x-demension cannot be high enough for a standard sterndrive installation in any low freeboard hull, such as yours. need a deeper hull that will accomodate a much higher x & its thru-transom exhaust exits & its engine height under an engine hatch...
    ...now, with that being said...the alpha transom cutout on your installation is usable for a bravo transom plate. you buy a bravo transom plate & a short bravo sportmaster drive & your cook'n. a new higher pitch solid hub stainless prop will be needed. the external steering you should have, along with that, well...thats a different story...
    ...i'm also an LS guy. what LS did you go with?...
  1. Sidewinder 18'?
    By akeemb86 in forum General Boating Discussion
    Last Post: 10-30-2017, 03:54 PM
  2. Sidewinder
    By Greg G in forum Ebay Listings and Other Internet Listings
    Last Post: 02-10-2017, 05:31 PM
  3. sidewinder
    By badluck in forum General Boating Discussion
    Last Post: 03-05-2014, 08:12 PM
  4. Sidewinder
    By Airboater in forum Technical Discussion
    Last Post: 04-01-2002, 12:58 PM
