Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
    Plainville, CT
    Quote Originally Posted by rhardwick View Post
    Is this a Mercury fuel pump or aftermarket? I would only trust a Mercury fuel pump.
    The zero pressure was on a brand new non-merc fuel pump. So sounds like you're right to trust only the Mercury one.
    So the test at the lake proved that the rebuilt Mercury pump had corrected a problem. It ran fine on the external tank at all speeds and sustained it.
    When I hooked it up to the internal tank it failed again. So obviously there is still a problem with that system somewhere. I started with replacing the ball and immediately adjacent lines. Recently I had already replaced the pickup tube in the tank and the anti-siphon valve. This all seemed to pump by hand OK, but several locals are telling me to remove the anti-siphon valve entirely... even though it may be brand new they are bad news.
    Anyone else have an opinion about anti-siphon valves?
  2. #17
    Pekin, IL
    Unless your motor is lower than the fuel tank remove it.
    Rock
    Team Junk
  3. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  1. 1989 Mercury 80hp Upgrade
    By Glastron1987 in forum Technical Discussion
    Last Post: 08-17-2020, 05:40 AM
  2. Mercury 80HP triple rebuild.
    By rev.ronnie in forum Technical Discussion
    Last Post: 03-25-2012, 12:22 AM
