Results 1 to 7 of 7
    May 2005
    Louisiana
    yamaha F150 balance shaft delete
    has anyone fone this yet ? is it possible ? seems like a flawed design ! thanks
    May 2005
    Louisiana
    i guess no
    reply means no ?
    Lots on internet... 6 - 8 hours work, vibrates badly without. What else is there to know?
    Nov 2019
    Canada
    I'm not sure why you would want to do this. Nearly every inline 4 motor has some sort of balancing system. They need it by design to eliminate vibration.
    www.InjectorService.com
    Call/Text - 204-326-0390
  5. Likes FORBESAUTO liked this post
    Nov 2019
    Canada
    To add to my earlier post, oddly enough I actually had been looking at an F150 earlier in the morning that had a bad knock and vibration. I don't know what part took what out, but I figure it went like this. Balancer bearing went out, which killed the balancer gear. Once that happened the motor shook itself so hard it took out a rod bearing.
    Nov 2009
    hardyville va
    I have multiple F150's running without balance shafts. Can't feel any difference at speed. Tiny vibration at 15 to 2000. Try it. Take out the shafts, tap oil hole in balancer, plug with allen set screw. You will never buy that $400 piece of junk again.
  8. Thanks David - WI thanked for this post
    Nov 2009
    hardyville va
    Quote Originally Posted by InjectorService View Post
    What happens, the junk plastic gear wears down, the plastic clogs oil passages, rod bearings go. The balancer usually whines for a while before it goes. All the early ones failed, Yamaha re-called some. They have been updated a couple times over the years. Honda and Suzuki's use chains to drive.
  10. Thanks InjectorService thanked for this post
  1. Yamaha f150 flushing problems
    By Whaaaaat in forum Technical Discussion
    Last Post: 08-16-2019, 06:24 AM
  2. Yamaha F150 Lower Unit
    By MERCSPEED in forum Lower Units
    Last Post: 10-31-2018, 03:34 PM
  3. Yamaha F150 on 2005 Bay Scout
    By Rudeman89 in forum Props, Setup, and Rigging
    Last Post: 12-18-2015, 01:42 PM
  4. Yamaha F150 Rod Length?
    By W. Tripp in forum Technical Discussion
    Last Post: 02-29-2004, 07:59 AM
