Results 1 to 6 of 6
Thread: Supporting a V-King
07-12-2022, 11:15 AM #1Junior Member
- Jul 2005
- Oshawa
- 7
Supporting a V-King
I just bought a V-King and the trailer has a total of 8 easy-rollers. The back 4 rollers are about 14" forward of the transom and the other 4 are about 24" further forward. There is a V support under the keel beneath the windshield. So 9 fairly small supports.
Should it be on bunks? If so where should they lie and how long should they be?
07-12-2022, 11:37 AM #2
Bunks 100%
I run four. Two 10’ 2x6 in the area between the pad and the first chine and two 2x4x4’ under the outer stringersHydrostream dreamin
yjewel thanked for this post
07-12-2022, 12:36 PM #3
07-12-2022, 04:55 PM #4
I made a small mistake i was working on my trailer today my center bunks are 8’6” not 10’
07-13-2022, 10:03 AM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I use a two bunk trailer with the fwd keel resting on a v block. Bunks are 3”x6” rough cut lumber set vertically with carpet over. Keel is a combo of the same lumber as the bunks with a slight v cut into it. I use a pc of plastic board to cover the wood and make a slick surface for easy launch and retrieve been on this trailer for over 5 years no problem. My king does have a very strong bottom and the bunks contact the hull where the floor meets the hull
07-16-2022, 05:48 PM #6
I used poly bunk covers on the wood and ran the outer ones longer so I could step up to get into the boat instead of the fenders. Makes it easier to wax the top of the cowl to.
(Apricot)
Hydrostream Ventura II/Merc (sold)
(Bruiser Scheme)
Hydrostream Viking/Merc (sold)
(tri color letdown scheme)
Hydrostream Valero/Merc
Trying so become supporting member
By Will hedrick in forum Scream And Fly Team MembershipReplies: 9Last Post: 05-08-2021, 11:09 AM -
Supporting the hull
By Fibertron in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 12-31-2003, 05:43 PM -
Supporting.........
By kathy in forum General Boating DiscussionReplies: 0Last Post: 10-20-2001, 09:16 PM
