Results 1 to 6 of 6
    Jul 2005
    Oshawa
    Supporting a V-King
    I just bought a V-King and the trailer has a total of 8 easy-rollers. The back 4 rollers are about 14" forward of the transom and the other 4 are about 24" further forward. There is a V support under the keel beneath the windshield. So 9 fairly small supports.
    Should it be on bunks? If so where should they lie and how long should they be?
    Jun 2018
    Floating around
    Bunks 100%
    I run four. Two 10’ 2x6 in the area between the pad and the first chine and two 2x4x4’ under the outer stringers
  3. Thanks yjewel thanked for this post
    Aug 2021
    Osteen/Deltona, FL
    Bunks 100%
    This is also how mine is now setup.
    83 Vking 150 Mariner 2.5L
  5. Thanks yjewel thanked for this post
    Likes LakeFever liked this post
    Jun 2018
    Floating around
    I made a small mistake i was working on my trailer today my center bunks are 8’6” not 10’
    I use a two bunk trailer with the fwd keel resting on a v block. Bunks are 3”x6” rough cut lumber set vertically with carpet over. Keel is a combo of the same lumber as the bunks with a slight v cut into it. I use a pc of plastic board to cover the wood and make a slick surface for easy launch and retrieve been on this trailer for over 5 years no problem. My king does have a very strong bottom and the bunks contact the hull where the floor meets the hull
    Jun 2004
    Lakeridge NY
    I used poly bunk covers on the wood and ran the outer ones longer so I could step up to get into the boat instead of the fenders. Makes it easier to wax the top of the cowl to.
    Attached Thumbnails Attached Thumbnails 9277C953-2E92-4494-BD4B-D00EF89DA885.jpeg
    (Apricot)
    Hydrostream Ventura II/Merc
    (sold)
    (Bruiser Scheme)
    Hydrostream Viking/Merc
    (sold)
    (tri color letdown scheme)
    Hydrostream Valero/Merc
  9. Thanks yjewel thanked for this post
  1. Trying so become supporting member
    By Will hedrick in forum Scream And Fly Team Membership
    Last Post: 05-08-2021, 11:09 AM
  2. Supporting the hull
    By Fibertron in forum Fiberglass and Composites Discussion
    Last Post: 12-31-2003, 05:43 PM
  3. Supporting.........
    By kathy in forum General Boating Discussion
    Last Post: 10-20-2001, 09:16 PM
