Page 6 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 76 to 90 of 191
  1. #76
    I've watched many Mercury 4 stroke go under, pickled, and brought back to service. I feel that there will always be gremlins in those motors once they have gone under..
    there are hundreds of connectors that were not meant to get wet no matter how much CRC spray you put on them
    let's see how they run in this weekend's races
  2. #77
    8 Post(s)
    Quote Originally Posted by noli View Post
    I notice out here in Asia when a 4 stroke goes under in the salt the dealers want to do a full electrical replacement so the engines are usually scrapped, this is mostly 100hp and below as the common sunk engine.
    ( of course the carby engines just keep running)
  3. Likes noli liked this post
  4. #78
    My thoughts exactly, still a great motor!
  5. #79
    Michigan city race Super Stock just ended
    Glad everyone is ok.
    LPC lost a motor. Did the motor sink or still attached on the LPC boat?
  6. #80
    Chaz = wunderin, will merkury send me a check for namin the porkchop ... correctly .. ???
  7. #81
    My well connected spy tells me that the motor didn't go to the bottom. It was pulled to the dock via the tow ... errr ... tie bar ...
    Chaz = thinkin, glad me ole $hiz-box has two-strokes and a wooden transom --->
  8. Thanks noli thanked for this post
  9. #82
    I remember seeing the port side sinking a little bit
    Was there water intrusion into the hull from the incident?
    Man LPC were flying on that course today before the incident
  10. #83
    Apr 2010
    Indian Lake Ohio
    Was the incident contact or just the motor coming off on its own? Were can race results be viewed if one missed the live stream? Thanks
  11. #84
    Lake Rat, the video I watched was on FB, but has been taken down
  12. #85
    Hey,
    I didn't know LPC uses a tunnel-tab
  13. #86
    PARADISE /Naples
    hole in transom?
  14. #87
    Yes sir
    At first I thought the STR bracket failed...it seems the transom failed on this one
  15. #88
    Maybe the transom skins should have Kevlar in the schedule?
    I might go back to Marine plywood on my transom build
  16. #89
    PARADISE /Naples
    Be interested looking in that hole to see how it was built,
    Noli you went over kill on yours, did not want to say anything but I never heard of anyone using two 2 inch sheets to built a transom unless you'll have 4-5 motors back there.
    Kevlar is not the answer, carbon is strength and I like aluminum on the inside because of bolt hole compression, but that whole section is gone... CRAZY
  17. #90
    May 2019
    New Buffalo, MI / Melbourne, FL
    How did that new Steele boat do?
  1. New 450hp stock class
    By CUDA in forum General Boating Discussion
    Last Post: 06-01-2021, 09:59 AM
  2. 2.4 build for stock class
    By coffeeguy in forum Technical Discussion
    Last Post: 03-11-2018, 08:19 AM
  3. Jasper stock and bass,ski class
    By hydrostream1 in forum General Boating Discussion
    Last Post: 10-11-2012, 03:33 PM
  4. Odba Super Stock Class
    By mike andreola in forum General Boating Discussion
    Last Post: 07-03-2002, 01:23 PM
