Results 1 to 15 of 16
    Nov 2004
    Safety Harbor
    New v8 300proxs running problem
    So I just got my new v8 300proxs. It has prob only 3 hours if that on it. I have not ran it wide open and nothing above 4200 rpm. So I have 2 gas tanks on my lake and one in front and one in the rear. I had no issues for prob 10 to 15 gal of gas. Then the motor started to buck or feel like a fuel flow issue so I switched tanks still the problem persisted. I could idle no problems get on plane get up to 3500 to 3700 and then it would start bucking again and then did that at lower and lower rpm to where I could only idle. So when I got back in I checked the manual gas tank selector that' was fine. So I checked hoses on each tank all the way to the fuel water separator on the motor nothing seems out of ordinary. After that went out ran it again no issue for prob 3 gallons keeping it at 3800 rpm or less. Once I tried to get above 4k it started bucking mildly at first then got worse and continued to do it at lower rpms until idle again. I thought maybe a hose was loose but they all were tight. Then I thought fuel filter/water separator may have got junk in it from running tank low but that seemed fine blowing through it and I just had my tanks pumped and cleaned. I also have been redoing the whole boat so whole new re wire of the boat, new fuel lines new lithium batteries trolling motor ect rigged by boattronics in jacksonville. If anybody has any idea on all ears
    Thanks for any help
    Mar 2022
    Lake Travis Texas
    No engine alarms? Are tank vents clear? Can you run on a remote tank? Can you feel the primer bulb while running? Are volts stable at 14 Volts?
    Jim
    Nov 2004
    Safety Harbor
    Quote Originally Posted by Jim Speros View Post
    No faults or engine alarms vents seem clear blowing into lines. When boattronics ran new gas lines they didn't install primer bulb so I was going to put one on and try that next.
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Boozin909 View Post
    Don't add a bulb.
    Check the fuel restrictions. You can watch the fuel trim.with G3
    Sep 2019
    Lake Keowee, SC
    I have a 300R and it did something similar but at higher rpm and it just kept getting worse. Finally, Don Weed at European Marine found the issue quickly and corrected it. A faulty fuel injection wire harness on #7 cylinder caused a large misfire that resulted in the engine going very rich and back to lean. The wire harness was repaired, and the plug wires all changed under warranty and 50 hours later still performing well.
    35 Post(s)
    Problem Diagnosis
    Thanks for any help
    If you didn't install a new wiring harness with your V8 ProXS, you should do that. Also, you need a dedicated clean power circuit from the primary battery to the ECU.
    Your ECU should be spitting out error codes to easily diagnose the problem. Change EVERY fuel filter you've got and run fuel directly to the engine from a pristinely clean small tank so you can isolate one problem at a time. Again, your ECU should be telling you what's failing. Your dealer's laptop should tell you what the problem is in 5 minutes. Having your tanks "cleaned" maybe causing more fuel debris problems than you think.
    St. Pete Fl
    Quote Originally Posted by WaterZebra View Post
    just because there is a run issue does not mean the computer is going to give him a fault code. If there is no alarm, there will be no stored codes. With this being a brand new engine, he should take it back to the dealer that installed it and have them diagnose it. I would expect the clean power was installed as the engine would not run without it, but all connections should be checked as well
    Also, as it was stated before in this post, do not install a primer bulb
    Sep 2019
    Lake Keowee, SC
    My 300R did not store any codes when we had the faulty injector wire harness on #7, and as mentioned above, no alarm went off either. Just ran very poorly.
    Jul 2021
    Pompano Beach
    Also for break in, you're supposed to run WOT for 1 minute every 2 minutes for the first 2 hours to seat the rings varying rpms otherwise and staying under 4500. Then hours 2-10, vary rpms staying under 4500, and then wot no more than 5 minutes at a time. Once you get this resolved I would do the proper break in ASAP.
    35 Post(s)
    BoatTronics
    Thanks for any help
    It appears that BoatTronics specializes in electrical stuff. So who did your 300ProXS installation?
    7 Post(s)
    Man I wish I had a pair of these!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  12. #12
    Jul 2021
    Pompano Beach
    Wait, do you have a lithium starting battery????? Is it a Dakota that is rated as a dual purpose battery, or just a lithium battery? I'm willing to bet it's the BMS shutting the battery off and on.......put an AGM battery in and see what it does.
  13. #13
    35 Post(s)
    Lithium Battery = Bad Idea AGM Battery = Good Idea
    Quote Originally Posted by Capt j View Post
    Lithium batteries (at this point in time) are a bad investment for marine power. AGM is a solid dependable choice and could eliminate the BMS gremlin. As I said before, make sure your ProXS has a CLEAN POWER CIRCUIT to the ECU.
  14. #14
    May 2001
    Ga
    We have seen some of the V6 and V8 mercs fail the hi psi fuel pump very early on . It’s officially called a fuel module . Sounds like yours may be bad . Hf…
  15. #15
    Sep 2017
    ontario
    Interesting point on the hi pressure fuel pumps - is this a sitting long periods . Stuck pumps -
    When I purchased an opti - 200xs - I had heard mention of it - his remedy was run pump backwards momentarily - it worked and has run the Merc fuel conditioner since .
    So I'm not sure on what fuel pump frequency your seeing - can you expand the issue .
  1. WTB 300PROXS 25” mid
    By Noodle1422 in forum Engines Wanted
    Last Post: 04-11-2021, 10:30 PM
  2. Replies: 8
    Last Post: 03-09-2011, 11:30 AM
  3. Any body have a problem with running to cool?
    By WATERWINGS in forum Technical Discussion
    Last Post: 09-19-2010, 10:11 PM
  4. 2.5 260 analog running problem
    By mrcrsr in forum Technical Discussion
    Last Post: 11-17-2007, 05:02 PM
