Results 1 to 15 of 17
    Massapequa NY
    Twin 225 Pro Max water temp issue
    At my wits end with this. Replace 200ff blocks with 225 Pro Max powerheads on 25” bass mids with standard gear cases. Powerheads had/have less than 3% leakdown and perfect compression when I bought them. Mechanic strongly suggested “free flow” cooling which I believe is no thermostats or poppets? Lowered motors down to lowest setting. Replaced water pumps. Had top two holes of gearcases closed. Port motor is fine and operates with correct pressure and temp. Starboard motor. On hose, turn up to 2000 then 3000 rpm, no issues. Put boat in water, heats up at canal speeds with hardly any “pissing. Horn go off and temp goes up. Limp in on one motor. Back at dock in water, 2000,3000 rpm pisses and temp is fine. I have a guy who wants boat but will not sell it to him this way until problem is solved. Anyone have any ideas or suggestions? Thank you in advancd
    Kind of a pain; but if you swap the lower units... you narrow it down to motor or lower?
    Massapequa NY
    Was thinking that. Going to putter around today. Too nice out.
  4. Likes David - WI liked this post
    Mar 2022
    Lake Travis Texas
    If you don't see anything unusual with gearcase , pumps tubes. While they are off rig a garden hose to water tube and flow hose pressure thru with engines off. See if both sides flow the same.
    Jim
    Massapequa NY
    Quote Originally Posted by Jim Speros View Post
    got it, thanks
    TX......somewhere?
    ya lost me at "free flow" ona bass (2 piece plates) mid??? never heard of such a thing?......
    May 2001
    Madison, WI
    Maybe you picked up some stuff in the canal causing a internal restriction. Maybe those side screens in the water intakes are hiding something in there?
    Sure hope is something simple for ya. The muck or sand might be packed up inside or jammed up stats. Hope not.
  9. #8
    Massapequa NY
    mechanic referred to free flow as removing t stats and poppets. Said what is done with 260’s etc. I believe he used the existing adaptor plates that were from the 200s.
  10. #9
    Massapequa NY
    Quote Originally Posted by scott reierson View Post
    Hey Scott, hope all is well by you. Don’t think I picked up anything because it pumps water on land. Its when I shift it into gear. No screens on these lowers. He plugged the top two holes because he said I was sucking in air due to props raising stern of boat
  11. #10
    Hope you don't lose the powerheads Mike. If some total retard pulled the stats and poppets, you won't even be able to fill the blocks.
  12. Likes tlwjkw, FORBESAUTO liked this post
    TX......somewhere?
    Quote Originally Posted by mragu View Post
    ya might consider findin' 'nother guy.. thats tha dumbest thing ya can do for coolin' to a production 2 piece plate motor thats nowhere near tha same as tha 260/280 stuff.... jmo.
  14. Likes FORBESAUTO, transomstand liked this post
    MIAMI FLORIDA
    Take a little tension out of the popet valve spring, I have seen that problem in the summer down here mostly on 25in motors. The problem is in the 1200 1500 range on long idle zones then they cool off as soon as the rpm/ pressure goes up and the popet opens allowing water to flow thru the block.
  16. #13
    This is really the key. Depending on if the powerheads are on 1 or 2 piece plates, the diagnostics and recommendations will be a good bit different for each. The 200 motors would have had 2 piece plates from the factory.
    TX......somewhere?
    Quote Originally Posted by H2OPERF View Post
    he says they don't have poppets or stats/restrictor washers???
  18. #15
    MIAMI FLORIDA
    Sorry didn't read the whole post. Thx
  1. 25 Eliminator Daytona twin 300r water pressure issue
    By city in forum General Boating Discussion
    Last Post: 08-06-2020, 10:43 PM
  2. Mercury Tech: Dual temp gauges issue OR engine Issue
    By dompie99 in forum Technical Discussion
    Last Post: 05-24-2016, 09:37 AM
  3. Mercury Tech: 2.4 200 water temp issue
    By Hunter Thompson in forum Technical Discussion
    Last Post: 08-05-2011, 07:22 PM
  4. water temp/pressure issue on a 225 pro max
    By John Dorn in forum Technical Discussion
    Last Post: 08-02-2011, 05:27 AM
  5. Gaffrig Water Temp Issue
    By That's Right in forum Technical Discussion
    Last Post: 05-03-2011, 02:55 PM
