Results 1 to 15 of 17
07-03-2022, 12:07 PM #1
Twin 225 Pro Max water temp issue
At my wits end with this. Replace 200ff blocks with 225 Pro Max powerheads on 25” bass mids with standard gear cases. Powerheads had/have less than 3% leakdown and perfect compression when I bought them. Mechanic strongly suggested “free flow” cooling which I believe is no thermostats or poppets? Lowered motors down to lowest setting. Replaced water pumps. Had top two holes of gearcases closed. Port motor is fine and operates with correct pressure and temp. Starboard motor. On hose, turn up to 2000 then 3000 rpm, no issues. Put boat in water, heats up at canal speeds with hardly any “pissing. Horn go off and temp goes up. Limp in on one motor. Back at dock in water, 2000,3000 rpm pisses and temp is fine. I have a guy who wants boat but will not sell it to him this way until problem is solved. Anyone have any ideas or suggestions? Thank you in advancd
07-03-2022, 12:19 PM #2
Kind of a pain; but if you swap the lower units... you narrow it down to motor or lower?
07-03-2022, 12:34 PM #3
David - WI liked this post
07-03-2022, 01:52 PM #4
If you don't see anything unusual with gearcase , pumps tubes. While they are off rig a garden hose to water tube and flow hose pressure thru with engines off. See if both sides flow the same.
Jim
07-03-2022, 02:36 PM #5
07-03-2022, 02:46 PM #6
ya lost me at "free flow" ona bass (2 piece plates) mid??? never heard of such a thing?......
07-03-2022, 03:03 PM #76000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 498
- 198
Maybe you picked up some stuff in the canal causing a internal restriction. Maybe those side screens in the water intakes are hiding something in there?
Sure hope is something simple for ya. The muck or sand might be packed up inside or jammed up stats. Hope not.Last edited by scott reierson; 07-03-2022 at 03:06 PM.
07-03-2022, 07:23 PM #8
07-03-2022, 07:25 PM #9
07-03-2022, 10:44 PM #10
Hope you don't lose the powerheads Mike. If some total retard pulled the stats and poppets, you won't even be able to fill the blocks.
tlwjkw, FORBESAUTO liked this post
07-04-2022, 12:42 AM #11
FORBESAUTO, transomstand liked this post
07-04-2022, 07:02 AM #12
Take a little tension out of the popet valve spring, I have seen that problem in the summer down here mostly on 25in motors. The problem is in the 1200 1500 range on long idle zones then they cool off as soon as the rpm/ pressure goes up and the popet opens allowing water to flow thru the block.
07-04-2022, 07:37 AM #13Living in the Freedom provided by Bud Conner and his fellow warriors.
07-04-2022, 09:27 AM #14
07-04-2022, 10:35 AM #15
Sorry didn't read the whole post. Thx
25 Eliminator Daytona twin 300r water pressure issue
By city in forum General Boating DiscussionReplies: 20Last Post: 08-06-2020, 10:43 PM -
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
Mercury Tech: 2.4 200 water temp issue
By Hunter Thompson in forum Technical DiscussionReplies: 5Last Post: 08-05-2011, 07:22 PM -
water temp/pressure issue on a 225 pro max
By John Dorn in forum Technical DiscussionReplies: 7Last Post: 08-02-2011, 05:27 AM -
Gaffrig Water Temp Issue
By That's Right in forum Technical DiscussionReplies: 4Last Post: 05-03-2011, 02:55 PM
