Results 1 to 5 of 5
    Jun 2018
    Floating around
    Transom holes, what size to drill?
    im making a transom drill guide plate and stopped tonight at what size to drill the holes? Typically i go one size over for bolt holes so a half inch bolt would be 33/64 or even 17/32 which works great. My transom is coosa so i wont be doing epoxy in the holes i will be installing 1/2” fine thread studs with brass nylocs. I’ll be sealing the holes with 5200 or 4200 im undecided on which yet but probably 5200 because the studs can stay if i change up jack plates later on although thats unlikely because i bought a new seastar.
    anyways what size should i drill the holes? Im thinking spot on half inch might be best but I want to hear from you guys before i commit to that. Thanks
    Jun 2018
    Floating around
    I dont know what happened to my one and only 33/64” drill bit but I tested in a scrap piece of 3/4” coosa with a 17/32” hole and a 1/2” hole and the 17/32” is too large the 1/2” 316 rod im making the studs out of wobbled around way too much for my liking. While the 1/2” was tight being zero clearance I feel more confident with it so thats the direction im going. Feel free to chime in any other thoughts about this maybe it will help someone else.
    Jun 2018
    Floating around
    Definitely happy with half inch holes. Made a new engine stand for my new motor so i tested my transom drill fixture guide plate deal out. Worked slick and made this very easy. Plate is 16”x12” with bia pattern and a tiny hole dead center to aid in alignment. The blocks are 3/4” plate. I laid out the drill pattern on the 1/8” cold roll plate using a scribe for accuracy, marked, center punched, then drilled with a 1/16” bit. I cut the 3/4” plate by eye around 1” square pieces and clamped them to the plate, used a mig to tack them in place. Then using my pre drilled 1/16” pilot holes i drilled them out to half inch on the drill press
ID:	506749 Click image for larger version.
    Sep 2017
    ontario
    I am of similar thoughts on 1/2 for 1/2 bolts and 5200 on install
    - large stainless washers as well .
  5. Likes LakeFever liked this post
    Jun 2018
    Floating around
    Agreed. I have a sheet of 1/2 aluminum im going to make backing plates/washers out of when i install onto the hull. They will be yuge
  1. Mercury Tech: Mercury bleed line drill bit size
    By 1BadAction in forum Technical Discussion
    Last Post: 10-29-2015, 06:59 PM
  2. New transom where do i drill for jackplate
    By mike19action in forum General Boating Discussion
    Last Post: 09-28-2014, 11:46 AM
  3. Filling different size holes in deck and transom glass?
    By CaryW in forum Fiberglass and Composites Discussion
    Last Post: 06-12-2011, 07:40 PM
  4. do I drill 4 or 6 holes?
    By yachter55 in forum Props, Setup, and Rigging
    Last Post: 12-18-2008, 07:35 PM
