Results 1 to 3 of 3
    Dec 2018
    greenville, nc
    Abort factory breakin mode with ddt
    2000 optimax 150 was disconnected from batteries for a while and is in break in mode now. Can't find in ddt manual how to abort.
    When ddt is connected, it does not give me an option to abort.
    May 2001
    Ga
    Just gets more oil. I think you will need to run it.
    Sep 2017
    ontario
    As far as I know you cannot go around the break in mode - you either asked for break in through the DDT or you pumped the shifter 3 times and asked for the mode to begin . No big deal really - just run it and keep the oil up in the res, and if you topped or opened the res, on the motor - purge the air by idling the motor and res, cap loose untill oil begins to rise - tighten cap . Hopefully your running the Merc racing oil as directed in bulletin .
  1. Random Videos- still in breakin mode!
    By home made tunnel in forum General Boating Discussion
    Last Post: 08-05-2018, 12:41 PM
  2. Rookie Breakin
    By GGAARR in forum Technical Discussion
    Last Post: 11-25-2002, 08:54 AM
  3. breakin it in!!
    By vishus in forum Technical Discussion
    Last Post: 05-06-2002, 06:25 PM
