Results 1 to 9 of 9
Thread: any Harley mechanics?
06-18-2022, 07:56 AM #1
Brother-in-law has a 2014 Harley Trike and I cannot figure it out. Trying to hook up a trailer and what is happening makes no sense to me. Hook up to truck and lites work perfectly on trailer. Hook it to bike and left turn signal won't work. I have checked connections repeatedly and they are correct. We even took a new trailer lighting kit and hooked it up and had the same results. Any help or direction appreciated. Thanks
RockTeam Junk
06-18-2022, 11:59 AM #2Team Member
- Jun 2004
- long island
- 1,768
- 811
- 394
- 4232
- 4578
Did you try running a dedicated ground wire
rock thanked for this post
06-18-2022, 12:14 PM #3
Yes I did. I checked for continuity thru the plug on the bike then ran wires to bypass the trailer lighting to no avail. He had the bike at the local Harley shop and was charged $300 for them to tell him the trailer was the problem. That is how we came to have a complete new in the box system to replace what is on the trailer. Trailer lighting is so simple anyone should be able to get it done. I have come to the conclusion the Harley requires something we do not know about. Five wires on the bike go into a 6 pin connector but only 4 of the pins are actually used and one of them should be the ground but is not. That is why I think the issue is on the bike. I have been riding Harleys for many years and do not work on them other than to change oil. I understand boat motors. Thanks for the suggestion.
RockTeam Junk
06-18-2022, 01:30 PM #4
Thinking motorcycle has separate turn signal and brake vs auto that has turns combined with brake. I could be blowing smoke, as I never messed with wiring up lights on a bike.
06-19-2022, 08:54 AM #55000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
06-19-2022, 09:50 AM #6
Rock, do a internet search on "how to wire a trailer on a motorcycle" there's some good info at Kompact Kamp.
06-20-2022, 10:32 AM #76000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
06-21-2022, 09:28 AM #8
Randy
If the bike is factory wired and you have all but left turn as i read.
On all new trucks there are fuses for just the trailer lights.
This is if something shorts in the trailer it doesnt kill the truck lights like the old days.
On most they in the regular fuse box marked trailer tail left and right turn.
I have seen remote fuse boxs for this also. might look arond for a small fuse box.
Just an idea.
Dale
06-27-2022, 06:29 AM #95000 RPM
- Sep 2013
- sarasota, florida
- 748
- 12
- 12
- 48
lets make this easy.. ride up too your local trailer shop let them hook your plug to there magic box ,,,it will tell you exact wiring ,i only say this because ,,,,,been there done that !!!
hi everyone/mechanics
By ihatemels in forum Technical DiscussionReplies: 4Last Post: 04-23-2008, 06:22 PM -
GM mechanics - please help!
By Riverman in forum Tow Vehicles and TrailersReplies: 18Last Post: 03-31-2006, 09:30 AM -
Getting to know more about mechanics
By Pete in forum General Boating DiscussionReplies: 1Last Post: 03-18-2002, 09:06 AM -
By Pete in forum Technical DiscussionReplies: 5Last Post: 03-18-2002, 08:26 AM
