Results 1 to 3 of 3
06-15-2022, 07:15 PM #15000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
90 HP Yamaha prop cotter Pin Size.
Going to change the prop on the pontoon at the lake and figured I should have a spare cotter pin incase the original gets damaged during the removal, anyone know off hand the size? The motor is a 2018 90 HP 4 stroke. If the boat wasn't 3 hours away I would just do a visual but I want to pick one up before the weekend. Thanks
06-16-2022, 04:05 PM #25000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
The biggest Home Depot carries is 1/8 diameter in stainless (various lengths), that seems a little small
06-17-2022, 01:05 PM #35000 RPM
- Feb 2002
- The great corn desert of Iowa
- 298
- 41
- 200
I had a 2 stroke 90 on a pontoon boat and that took a 5/32 by 1 1/2. You could just use a drill bit to get the right diameter and then measure across the castle nut and add some.
1971 Sidewinder 14 SS w Johnson 90 v-4
1959 Texas Maid Falcon w Mercury Mark 35A
1981 Sylvan Sportster w Johnson 85 v-4
2006 Harris pontoon with a Yamaha 90
1969 Sunfish sailboat
yamaha v4 v6 first gen JET O-Ring size and material
By mackeral5 in forum Technical DiscussionReplies: 9Last Post: 10-08-2014, 06:38 PM -
Yamaha - Gear case size 3cyl 90 / V6 150 - the same?
By Stoker1 in forum General Boating DiscussionReplies: 2Last Post: 03-13-2014, 07:36 PM -
cant get the right size prop
By tyst67 in forum Props, Setup, and RiggingReplies: 6Last Post: 04-09-2011, 07:51 PM -
yamaha lower unit bolt size
By jay j in forum General Boating DiscussionReplies: 2Last Post: 04-06-2011, 07:57 PM -
Stock 2000 Yamaha 150 jet size question
By Skeet in forum Technical DiscussionReplies: 1Last Post: 10-11-2002, 08:13 PM
