Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 55
    Jan 2018
    Anderson, SC
    Quote Originally Posted by rgsauger View Post
    You are double nutting the studs and not using vice grips, right? Right???! Just checking...
    Not sure why I did not think of that, thank you for pointing that out. Luckily I put the vise grips on the one with the striped threads and it did not budge.
  2. #17
    Jan 2018
    Anderson, SC
    Any idea why the port head is cleaner in spots (#6) and looks burnt in others (#2 & 4)?
    I assume carbon build up on top of the pistons?
  3. #18
    Jun 2018
    Floating around
    Make sure to disassemble and clean the carbs up while your at it. New needles and seats are never a bad plan. Do the steel cage bearings and pro rod bolt upgrade. Low buck but gives you some stoutness
  4. Thanks thesignguy thanked for this post
    Likes rgsauger liked this post
  5. #19
    Jan 2018
    Anderson, SC
    I still have not ordered anything until I get it tore down and do a complete "recommendation" as to what to proceed with. Some of the caps on the rods are different colors, did they grind material away to balance them? Looks like #1, 2 and some of #3 have a Red coating #4, 5 and 6 look like bare metal, I'll have pictures tomorrow. Just curious....
  6. #20
    Pekin, IL
    Someone was probably trying to balance them. One of the great parts about these motors is how many parts will interchange. That is also one of the most difficult parts to learn. Those rods may be original but very possibly not. Keep going, you're doing great.
    Rock
    Team Junk
  7. Thanks thesignguy thanked for this post
    Likes Merc 2.5 liked this post
  8. #21
    Dec 2021
    NV
    related info that may be relevant
    I am currently disassembling a 2.4L (1985) due to low compression on #1. Compression is 115 vs 130-135 for all other cylinders. Mine is a 2.4L chrome bore though. When I pulled the first piston/connecting rod, the large end needle bearings were not captive in the races (original engine, first time apart). Is this normal? Pictures of current products seem to imply they are captive. Any help would be appreciated.
  9. #22
    Pekin, IL
    Many are not captured. You can buy them both ways.
    Rock
    Team Junk
  10. #23
    Jan 2018
    Anderson, SC
    Any suggestions to get the flywheel lock nut off? I don't have the flywheel holder wrench, I've put heat on it and soaking it with deep creep with an impact with a no-go.
  11. #24
    Houston, TX
    You can wrap a ratchet strap around the flywheel and secure it pretty good. Should be plenty for a good impact to knock the nut off. Then, you need the flywheel puller tool. About $35 or so on eBay. No substitute. Regulars pullers do NOT work. Good luck
  12. Thanks thesignguy thanked for this post
  13. #25
    Jan 2018
    Anderson, SC
    Finally got it all disassembled. I took some pictures but thought a video would give you a better look. Looks like I may need some new pistons as well, the one is pretty scored. Cylinders wall looked okay to me but not really sure what is good or bad. Also when removing the bearings from the rods some of the bearings were caged and stayed in while other just fell out, any input or is that normal?
    I'm also looking for a engine parts. I need a replacement head and the exhaust divider plate, it cracked in 4 pieces when I removed it.
    https://www.youtube.com/watch?v=HUgSH4UKkCc
  14. #26
    Jun 2018
    Floating around
    Looks like 4+5 are different pistons and i saw 0.40 stamped on top of one which suggests oversize. The cyls are not great but not terrible. Almost look chrome but cant be if oversized so maybe just thin? This is beyond my experience with these motas someone else can spell that out better. You could start with using acid on a q tip to remove the deposits in the bores to see how bad they are. Use caution with this process.
  15. Thanks thesignguy thanked for this post
  16. #27
    Houston, TX
    Muriatuc acid from a pool supply house. Do NOT get it on the aluminum block!!!!!!!
  17. Likes thesignguy liked this post
  18. #28
    Jun 2018
    Floating around
    Yes and keep multiple plastic cups of water handy in case of mistakes or spills pour on immediately to neutralize
  19. Likes thesignguy liked this post
  20. #29
    May 2013
    Huntiington Beach Ca
    Are you sure it's an 84 block? Looks more like a 78-81 with the older heads that mount to the cylinders not the block.
    It's not a 175hp 2L because the exhaust dumps aren't rectangle shaped.
    Those cylinders look to be chromed maybe the .040 piston got steel sleeved.
    You've got an oiler crank with non-oiler front half.
    Engine has been opened up and stuff replaced. All normal for a 40yo fishing motor
  21. Likes thesignguy, rock liked this post
  22. #30
    Dec 2021
    NV
    You can also use a mixture of baking soda and water. Baking soda neutralizes the acid just like cleaning the top of a battery.
  23. Likes thesignguy, LakeFever liked this post
  1. Opinions on new Merc 4 stoke 3.4 V6 motors.
    By JBS in forum General Boating Discussion
    Last Post: 02-28-2018, 06:09 PM
  2. is the 60 mercury 4 stoke worth buying?
    By robert jordan in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-06-2017, 12:08 PM
  3. Lower unit oil? 2 stoke oil?
    By 1fastg3 in forum Technical Discussion
    Last Post: 11-24-2010, 06:15 PM
  4. Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
    By rickyo in forum Technical Discussion
    Last Post: 06-05-2010, 04:08 PM
  5. Lucas semi synthetic 2 stoke oil?????????
    By GPRACING in forum Technical Discussion
    Last Post: 07-14-2009, 02:16 AM
