Results 1 to 6 of 6
Thread: 2001 X21 setup
06-13-2022, 09:23 PM #1Junior Member
- Oct 2011
- north carolina
- 19
2001 X21 setup
any have any experience w/x-21 with a 225 promax looking for props an motor heights any ideas will help
good holeshot w/25m prop but not getting rpms up to run due to losing water pressure
have turned it to 6100 but lost pressure an overheat comes on
thanks in advance
current setup previous setup
16" set back 12 setback
3.75 ptp 4.5 ptp
5200 53mph 5000 50 mph
lithium batteries
light load
losing water pressure at 1/4 trim
06-15-2022, 01:38 PM #2Team Member
- Lake Coochiching, Ontario
- 7,710
- 269
- 472
- 1542
- 6 Post(s)
Is this the boat? What lower unit is on your Promax? CLE or a Sportmaster or a Torquemaster?
Can you fix the water pressure by lowering the motor on the jackplate?
Xpress Boats X21 Review - Wired2Fish
06-15-2022, 03:05 PM #3Junior Member
- Oct 2011
- north carolina
- 19
it has a stock 2.5 200 lower unit no torquemaster an i have lowered the motor to 5.5 below pad an get the same results when i get past about 1/4 trim mark im overheating an losing pressure from 15psi to around 8 psi then it will kick off a overheat alarm bring it back down an within 15 seconds it will cut off the alarm
an yes it is that boat style but not the same boatLast edited by myob75; 06-15-2022 at 03:09 PM.
06-15-2022, 07:17 PM #4Team Member
- 7,710
- 269
- 472
- 1542
- 6 Post(s)
5.5" below the pad should be deep enough for no water pressure worries at all. And perhaps 8 psi is enough anyway, but you can't ignore the overheat alarm. Is the water pump good?
06-15-2022, 08:05 PM #5Junior Member
- Oct 2011
- north carolina
- 19
Brand new water pump checked the entire cooling system from the lower unit to the mid took the heads off an etc just to make no blockage
06-16-2022, 11:18 AM #6Team Member
- 7,710
- 269
- 472
- 1542
- 6 Post(s)
I got nothing, except that I don’t think your overheating is a prop problem. Maybe you could start another post about overheating in the technical section
2001 Liberator w/ 2001-300X
By bocephus in forum Hulls larger than 20'Replies: 35Last Post: 11-30-2020, 10:27 PM -
Help 2001 triton tr21 250 setup
By Cbrad23 in forum Bass Boats and Sport Fishing RigsReplies: 4Last Post: 11-01-2018, 07:03 AM -
Mercury 2000/2001 225 EFI & Mercury 2001 150 Carb
By aalbert in forum Outboard EnginesReplies: 10Last Post: 07-30-2016, 02:27 PM -
setup 19ft sebold eagle ski tunnel.setback and setup info plz
By boatdr72653 in forum Props, Setup, and RiggingReplies: 1Last Post: 09-06-2015, 09:10 AM
