Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: New Member
    Jun 2022
    NYS
    Ok Jim.... I looked at a quick view of backyard video. Looks pretty simple to me. Now I see how it works. My question is.... When I remove the outdrive - If the crank still does NOT turn over, then the motor itself is locked up I assume?
    https://youtu.be/mD3YcT2Ohrc
  2. #17
    Mar 2022
    Lake Travis Texas
    Quote Originally Posted by HydroStream 58 View Post
    Yes
    Jim
  3. Likes HydroStream 58 liked this post
  4. #18
    Jun 2022
    NYS
    Just one LAST question please? Then I'll remove the unit next week. What is the reason for putting it in forward gear before removal? Does it lock or release something in place etc...
    Thank you Jim....
  5. #19
    Mar 2022
    Lake Travis Texas
    Your pic shows its an Alpha 1 gen 1 drive. It does not have the speedo connection like the gen 2. However both units must be in forward to remove and install drive. {The complete unit top and bottom} The shift linkage dictate that. If its not in forward it is essentially locked on and if you force it damage to linkage is done. It is helpful to arrange the trailer in such a way the drive can go all the way down with out hitting the ground. Once trim cylinders and 6 bellhousing nuts are removed it may be necessary to lift and drop unit to break seal. If its rusted and u joints stuck bent persuasion may be necessary.
    Jim
  6. Likes HydroStream 58 liked this post
  7. #20
    Jun 2022
    NYS
    Got it !! Thank You.............
  8. #21
    Jun 2022
    NYS
ID:	506594I dropped the lower off. Jim was CORRECT !! About 1/2 gallon of water came out, bellows etc filled with oily sludge etc... Bearing is rusted TIGHT. It stayed in housing not on spline. Motor turns over by hand now but not great.
  9. Likes OnPad liked this post
  10. #22
    Jun 2018
    Floating around
    Ls swap if your feeling cheap dump a stock 6.0L in there from a truck and wire it yourself. If your feeling a little more spendy stick a cheap elgin cam and maybe go for the msd controller/carb intake with a 600 holley. That would take a day to prep the motor and a day or three to stab in there.
    or just change the oil, make sure the fuel supply is clean, fill the carb with gas through the vent tube and fire it up, if she no bang and clang? Ehhh might be ok. Those motas dont spin that nice by hand that wouldnt bother me. Spray some pb blaster in the spark plug holes and let soak for a few days before trying to start it
  11. Likes HydroStream 58 liked this post
  12. #23
    Jun 2022
    NYS
    Update, I decided to let the Eagle fly LOL, sold it. Thank you to all who help answer my question.
  1. Hello! New Member here!
    By ripperace in forum General Boating Discussion
    Last Post: 05-30-2013, 08:44 AM
  2. New Member
    By BAD ASS BOAT in forum General Boating Discussion
    Last Post: 08-01-2011, 02:33 PM
  3. New Member
    By LIBERATOR TEST PILOT in forum General Boating Discussion
    Last Post: 03-26-2004, 12:44 AM
  4. Welcome to a new Member !!!!!!!!!!!
    By Balzy in forum The Scream And Fly Lounge
    Last Post: 03-21-2004, 06:38 PM
  5. new member
    By mellowyellow in forum The Scream And Fly Lounge
    Last Post: 02-08-2004, 06:40 AM
