Results 1 to 8 of 8
Thread: 2.4 7 petal front half
06-06-2022, 08:13 AM #1
06-06-2022, 08:14 AM #2
06-08-2022, 12:54 PM #3
Member
- Sep 2021
- Buffalo, NY
- 41
- 64
how exactly would this improve my 150 xr4? Would my stock clamshell still fit?
06-08-2022, 03:23 PM #4
Clamshell would still fit. You would need a 7 petal reed plate to go with it, and a set of 7 petal reeds, but all of those are for sale around here right now from different people...It would be a good improvement for your xr4, they like the increased flow. If you have questions about specifics of bolting it all together and what you need to make it work send me or someone else on here thats done it before a private message and we will help you out.
06-09-2022, 10:49 AM #5
Like Jacob said, more flow for some more ponies!
1973 Viper
1978 Viking
07-04-2022, 04:40 AM #6
On a carb motor , more flow not always better , u would have to turn that motor 8k+ to actually notice the ex power , and bottom end won't b as strong, if it was efi I'd say yes it will make big improvement. Just my .02. If You go back thru the archives here , u will find 75% of people will say same thing
Also the only carb motos that came with 7 pedal was the old 2.4 225. , 91 2.5 200 (made 1 yr) and the 2.5 245. , which went to efi shortly after to make the 260. Just food for thought
Not tryin to defer a sell for you rj , just tryin throw out little info for a feller ,Last edited by Merc 2.5; 07-04-2022 at 04:46 AM.
07-04-2022, 07:35 AM #7
I’m wit Merc on this one. Not so bad on light boat, but if ya a little on tha heavy side, ya loose to much low end wit tha carbs. The lower velocity stinks and harder to get carbs right so they won’t load at extended idles also. Have run both set ups, my 7 petal may get another mph or so (questionable), but my 4 petal will skull drag it getting there.
07-22-2022, 09:58 AM #8
ttt
1973 Viper
1978 Viking
7petal front half VS 5 petal front half
By Dark Allison in forum Technical DiscussionReplies: 2Last Post: 08-28-2005, 08:52 PM -
10 PETAL INTAKE ON 14 PETAL FRONT HALF?
By Arizona Hotboater in forum Technical DiscussionReplies: 0Last Post: 04-21-2001, 11:43 PM
