Results 1 to 14 of 14
Thread: Delaminated?
    Jun 2017
    USA/CAN
    Delaminated?
    Hi everyone,
    came across this and was wondering is it delaminated or a set of bad repairs? The guy is very transparent sent me all the pics said it scraped the river bottom
    it’s cheap and was thinking may be good for a next winter project.
    Attached Thumbnails Attached Thumbnails 286F889C-51EC-44C1-AAEA-792864F47317.jpg
    Jun 2017
    USA/CAN
    Jun 2017
    USA/CAN
ID:	505501Click image for larger version.
    Jun 2018
    Floating around
    Mine looked similar in some places. I dont think thats delaminated. On my hull the factory chop had become whitened from what looks to be trailer impacts. There was a few small spots in other places like that too. While it felt solid’ish meaning we discovered this after the entire layup was completed, i was still very nervous to leave it alone so we ground out the bad spots and laid 1708 and 1oz csm over the entire hull.
    The main problem isnt the strike damage its the really poor quality factory glass. Every spot i had when i ground into it was full of pinholes and came apart with almost no effort. Took a lot of time to skin and fare that all back out
  5. Likes rgsauger liked this post
    The great corn desert of Iowa
    The bow damage is from scraping in the sand when power beaching the boat. The gouge in the side and strake looks like he smacked into a rock during the beaching. The damage around the pad and transom has me stumped. Can’t think of how you would gouge up that edge. Maybe by dragging the stern up on the sand so it’s anchored bow out?
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
    Houston, TX
    I agree with the statement that it does not look to be delamination. Just looks like some repairs that were made in haste. If you are looking for a project anyway and the price is right, it will probably be just fine once you repair it properly.
  8. Likes Aaronhl liked this post
    Jun 2009
    Bristol, Connecticut
    Looks like repairs to the pad area were made by grinding off the original gel coat and what he put over it has actually chipped off pretty badly, in the one pic you can see it looks like the whole under side from the middle to the transom has been repaired in some way or another...look at the inner chine it is not straight at all... Looks repairable with a bunch of efforts you will need to flip that one over, hopefully the damage does not go any further than the gel, first fiberglass layer...maybe it just looks bad from the staining sitting in the water
    Jun 2017
    USA/CAN
    Ended up with a different voyager, needs not nearly as much work. I will say with this 04 i was a bit suprised how loud the waves are against the hull. Boat drives amazing first thing to go is the 300X to my 250XS or 2.5.... The 300X has enough power to stain the drivers seat but eats to much gas/oil even at lower RPMs and is not well mannered for the no wake zones etc. i need to go through. I used 3-4X the amount of gas approx. in the same amount of time as my 250XS when cruising in the 3000RPM range but it def. has WAY more power and is in another world in that department.
    Are these composite cored? or no core maybe? The good thing is i have gotten some great interior ideas from it for the Vegas im rebuilding
ID:	506208Click image for larger version.
ID:	506209Click image for larger version.
  11. Likes LakeFever liked this post
    Jun 2017
    USA/CAN
    I wonder how much i can get for the 300x?
    Jun 2018
    Floating around
    Sweet boat!
  14. #11
    Quote Originally Posted by cameronj View Post
    Loud is good. Mushy hulls are nice and quiet and ride soft.
    Click for Countdown to the Romp
  1. concord hull delaminated
    By jeepster21 in forum General Boating Discussion
    Last Post: 08-14-2015, 05:12 PM
  2. My Valero delaminated today
    By jtaj77 in forum Fiberglass and Composites Discussion
    Last Post: 11-25-2010, 09:49 PM
  3. 80 vector delaminated... need a good shop
    By steady streamin in forum Fiberglass and Composites Discussion
    Last Post: 11-02-2008, 04:49 PM
  4. The bottom of my vegas delaminated and sank today!!!!!
    By baja200merk in forum General Boating Discussion
    Last Post: 03-18-2008, 03:35 PM
  5. Liberator Delaminated!!!
    By 78kona in forum General Boating Discussion
    Last Post: 09-29-2007, 06:05 AM
